Morimoto 2Stroke 3.0’s Low Beam
Discussion in '5th Gen 4Runners (2010-2024)' started by Ebadai98, Jan 31, 2021.
  1. Jan 31, 2021 at 11:05 AM
    Ebadai98
    Ebadai98 [OP] New Member
    18 TRD Off Road
    Has anyone installed the Morimoto 2Stroke 3.0’s and running them in the low beam? I’m having difficulty getting the passenger side to align in the housing properly so the diode is at 3&9.
  2. Feb 8, 2021 at 2:24 PM
    nightflyer
    nightflyer New Member
    Jason
    Ft Worth, TX
    2020 Venture
    I had the same issue, the driver side went into position with the chips at the 3/9 o’clock position but the passenger side did not. The base is supposed be adjustable but mine won’t budge. Did you ever get yours to adjust?
  3. Feb 10, 2021 at 8:22 PM
    Ebadai98
    18 TRD Off Road
    Sorry for the late response.
    Yes I did get mine to align properly. One of the collars came with a damaged tension spring, so morimoto sent me a new one. Having an extra set of collars, I decided to cut the larger tab down, similar to the H9 trim. Cutting the tab gave me the ability to put the collar in a different slot and fit perfectly afterwards.
  4. Feb 12, 2021 at 8:19 PM
    Ebadai98
    18 TRD Off Road
    Update:
    After driving a couple nights with these 3.0’s I will be returning them. For the price, I am not impressed by the light output at all. Switching back to my tried and true H9!
    Rainier42 and gunsnob like this.
  5. Feb 13, 2021 at 3:44 AM
    nightflyer
    Jason
    Ft Worth, TX
    2020 Venture
    The light is certainly more white but that’s about it, I ended up just putting the stock bulbs back in.
    Rainier42 likes this.
