Momentary radio and A/C cut while driving
Discussion in '5th Gen 4Runners (2010-2024)' started by Thycidides, Aug 31, 2021.
  1. Aug 31, 2021 at 7:00 PM
    Thycidides
    Thycidides [OP] New Member
    2017 grey TRD Offroad
    Hello,
    New member here. My wife's TRD Off-road recently has a weird issue. While driving the radio and A/C will cut for less than a second, then the A/C comes back and radio resets. This happens maybe once or twice in a twenty minute ride. Battery is pretty new and never gave us issues. Any ideas?
  2. Aug 31, 2021 at 7:01 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Have you checked your battery terminals?
  3. Aug 31, 2021 at 7:19 PM
    Thycidides
    Yes, they are both tight. What's weird is both A/C and Radio go out, but both are on different relays.
    n2oblivion likes this.
  4. Aug 31, 2021 at 7:25 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    Besides tightness, I would check corrosion. The thinnest layer can cause issues.
    Batteries regardless of age also do really strange things to vehicle electronics when they begin to fail, I'd also check the battery as well.
    I know these are "duh" kind of things but I've solved so many weird electrical gremlins starting there.
  5. Aug 31, 2021 at 7:32 PM
    Thycidides
    No, that's a good point. If the problem persists over the next few days, I'll get someone to scan the ECU via the ODBII port. I actually don't know much about this truck since it's my wife's vehicle. She drives a lifted 4Runner and I drive a lowered/tuned Evo. We are at opposite ends of the automotive spectrum. But I guess if everyone was the same, life would be boring.
  6. Aug 31, 2021 at 8:12 PM
    Electronic gremlins can be a real pain to chase down for sure.
    It seems to me after reading many posts on electrical issues that our vehicles are very sensitive to an underperforming battery or alternator. Also grounds that have been compromised can cause problems.
  7. Sep 1, 2021 at 5:34 AM
    Thycidides
    I'll come back to this post to follow up with what we find (if anything). Nothing worse than abandoned problems on the internet that help nobody.
    MeefZah and Polaars4 like this.
  8. Sep 1, 2021 at 5:54 AM
    JerryC
    JerryC New Member
    2021 Venture
    Does her 4Runner use a regular key?
    I've seen this on other vehicles that use a key switch, it gets a little play in it. Then if the drivers key chain is heavy it swings while driving and you lose accessory power.
  9. Sep 1, 2021 at 6:05 AM
    Thycidides
    That's good insight. She uses a regular key, but the vehicle is pretty new and everything seems pretty solid. So weird that both the AC and radio cut out for an instant. No other gauges go out as far as I can tell. I'm trying to capture the behavior on my phone, but it is tough to record. My wife insists of blasting Enrique Iglesias on the radio all the time, so I'm mostly covering my ears when I travel with her.
  10. Sep 1, 2021 at 6:37 PM
    Thycidides
    OK, I've got some good news for anyone with this problem. As it turns out, the battery connection was not on fully tight. It was tight enough to not be able to pull off, but you could (with reasonable effort) twist it on the post. So, it was tight, but not super tight.
    This was enough to periodically cut power for a fraction of a second. Tighten down your posts on these vehicles is the lesson learned.
    Jere39, MeefZah, PVT Pablo and 3 others like this.
  11. Sep 1, 2021 at 6:53 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    Jere39 and MeefZah like this.
  12. Jan 15, 2023 at 1:32 PM
    n2oblivion
    n2oblivion New Member
    Dew
    2016 4Runner SR5
    My runner is doing the same, although it’s only when I hit my brakes. The engine doesn’t stall or anything. It’s been below zero at night here a lot, but it starts every morning without hesitation, so I don’t think it’s a weak battery. It might be one day a month, but it does it in clusters. Could really use some more suggestions.
  13. Jan 15, 2023 at 4:24 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    If your battery is at least 3 years old, it’s the first culprit you should suspect. Have it tested.
    Also check the battery connections. And the alternator output.
  14. Jan 20, 2023 at 6:00 AM
    n2oblivion
    Dew
    2016 4Runner SR5
    So I decided to take a look at the battery connections even though they looked good from the outside. When I got them off I was flabbergasted with how much corrosion there was! Got everything cleaned up really well, and was really surprised by just how much effect it had. I’ve driven it for a couple of days and I haven’t had any more problems. Crossing my fingers.
  15. Oct 30, 2023 at 1:07 PM
    Brandonium
    Brandonium New Member
    So I have been battling this issue with the radio rebooting and my HVAC H/U rebooting at intermittent times, more often during turns and bumps. Sure enough I looked at my battery and my J-bolt was missing and the top bracket was sliding around arcing out on my positive battery terminal. Fingers crossed that this has been my issue.
