Middle Seat Flat Folding
Discussion in '5th Gen 4Runners (2010-2024)' started by esavi87, Nov 8, 2018.
  1. Nov 8, 2018 at 11:57 AM
    esavi87
    esavi87 [OP] .
    2017 TRD ORP/'15 SR5 Prem/'99 Limited
    Hello! I have a 2015 Sr5 premium model with the 3rd row seating option. I was unaware until yesterday that the 40 section (passenger side) of the 60/40 folding middle seats doesnt have the capability to fully fold flat. Has anyone been able to modify this?
    Strandskov likes this.
  2. Nov 8, 2018 at 9:28 PM
    WallyT4R
    WallyT4R New Member
    Are you talking about the ramp up, maybe 2 inches, between the rear seats and third row when the seat is folded? If the third row wasn't there it would just be the back storage area, is that what you mean?? Not understanding why only the 40 section won't fold flat?
  3. Nov 9, 2018 at 6:47 PM
    esavi87
    esavi87 [OP] .
    I've attached a picture, the one side folds down, but the other side only slides forward. I am wondering if there is a way to modify so the full backseat will fold flat.
    Pablo58 and (deleted member) like this.
  4. Nov 9, 2018 at 7:06 PM
    WallyT4R
    WallyT4R New Member
    Ahhhh...Thanks for the pic as that explains it all. Wow I didn't know the third row models were like that. I guess it's like that to allow access to the third row. Can't believe they can't make a seat that goes forward and still folds flat. I guess you could always go to the junk yard or shop for a 40 seat from a non third row model to fix this. But then it won't move forward to allow third row access. With little ones this probably won't matter as they can just climb in there with the flat folded seat. Hope you find a solution.
  5. Nov 9, 2018 at 8:09 PM
    edgesalon
    edgesalon New Member
    Te
    18 FunRunner :-)
    @esavi87
    your middle row has back and forward adjustment so move the seat back first with the latch by the bottom cushion by your legs not the one on the side that is for access to the third row then use the latch on the top of the seat fold and TADDA you get the whole back flat. :) hope this helps i will post pics
  6. Nov 10, 2018 at 2:45 AM
    WallyT4R
    WallyT4R New Member
    So it does fold flat! Problem solved. Glad I could help :D:D
  7. Nov 11, 2018 at 12:02 PM
    doc4216
    doc4216 New Member
    Shannon
    The Land of Cle
    2015 SR5 Premium
    Dasaíta HU, Bilstein 5100s, AT Tires, Coveted grill lights
    Adjust the bottom cushion of the seat fully to the rear using the lever by your feet and the seat will fold flat.
  8. Jan 29, 2020 at 9:56 AM
    esavi87
    esavi87 [OP] .
    @edgesalon Thank you for the response! I know i'm over a year late-I never got a notification and am just seeing this.
    Question-Does yours have the 3rd row option? Upon seeing this I ran out and tried, but it is totally non responsive when I pull the top lever, even when I have the bottom lever and the seat all the way back, per instructions. Almost feels like it's locked! Weird.
  9. Jan 29, 2020 at 10:50 AM
    Huzer21
    Huzer21 New Member
    CO
    2011 GX 460
    By top lever, the one on the seatback near where you right shoulder would be. Not the one on the side near the bottom seat cushion. That lever is for the third row access.
  10. Jan 29, 2020 at 11:06 AM
    esavi87
    esavi87 [OP] .
    Hi @Huzer21 ! Thanks for the response. That is exactly what I tried. I used the bottom slider to slide seat in the fully back position, and attempted to use the top lever (same as on the other side that pulls down the 60 portion), but no luck. It seemed stuck, almost as if it was locked. Weird! It makes total sense but just does not work!
  11. Jan 29, 2020 at 11:19 AM
    Did yours work to fold flat according to the instructions given?
  12. Jan 29, 2020 at 12:20 PM
    esavi87
    esavi87 [OP] .
    @glwood54 so far, no luck. I didn't have much time to get in there though so I will try again after work. I will post an update if I'm able to get it to function!
  13. Jan 30, 2020 at 5:41 AM
    Roberge01
    Roberge01 New Member
    I have a 2018 TRDORP and the middle row seat folds flat but I have to flip bottom of the seat up and forward first. There is a strap attached to the bottom portion of the seat that you lift up on to flip up and out of the way. Also the head rests need to be flipped down the for the seat to go down flat. It should all be the in owners manual, it's a beautiful thing.
    Instructions start on page 123 in my manual, they are pretty clear too.
    Strandskov, Charlievee and SlvrSlug like this.
  14. Jan 30, 2020 at 6:55 AM
    Charlievee
    Charlievee New Member
    Thats crazy talk. Next you will tell us, it can be downloaded from the interwebs for free!
    Strandskov and glwood54 like this.
  15. Jan 30, 2020 at 7:48 AM
    edgesalon
    Te
    18 FunRunner :-)
    he has 3rd row seats so its different than ones with only 2nd row seats only
    make sure the seat is all the way push back on the track
    it could be that the latch is stock your other side works then your have stock latch try some WD-40 or silicon lube spray at the latch area
  16. Jan 30, 2020 at 7:55 AM
    Roberge01
    I don't know that I would consider it crazy talk. Just trying to help out, not everyone checks the owners manual for info. Oh, and yeah it can be downloaded from the "interwebs" for free.
    4runningMan and Strandskov like this.
  17. Jan 30, 2020 at 12:04 PM
    I was asking @Strandskov, but feel free to chime in when you find out!
  18. Jan 30, 2020 at 12:06 PM
    2018 TRDORP with third row seating??
  19. Jan 30, 2020 at 10:27 PM
    Hey, no biggie! I was just curious to see if the instructions about sliding the seat all the way back in order to fold the seat flat had been tried on your 4R. Unless you already know yours folds flat...
  20. Jan 30, 2020 at 10:33 PM
    From what I've read, the third row seat 4Rs are all that way. If you look at the photo above posted by @edgesalon, the seatback sits on the bottom of the seat when folded down. Non-3rd row 4R rear seat bottoms fold forward, then the back folds down behind that.
  21. Jan 30, 2020 at 11:23 PM
    4runningMan
    4runningMan New Member
    New Mexico
    For people that plan to occasionally sleep in the back with the middle row seats folded down... the non-3rd row equipped models are a better choice. Those with 3rd row seats have a lot of bumps and gaps.
    This was one of the reasons I chose non-3rd row. It’s an overall longer flatter space. There is a big difference between the two models in how the middle row seats fold down. So, look closely.
    In 3rd row vehicles, the middle row seat back simply folds down onto the seat bottom. And there is a gap between that seat and the rear “platform”.
    In non-3rd row trucks, the middle row seat bottom lifts up and folds forward, and THEN the back folds down. So there is no gap between middle and back row, but there is a little hump. Seems to me there’s much more usable space overall.
    WallyT4R likes this.
  22. Feb 3, 2020 at 4:36 AM
    Roberge01
    No third row seating. I thought the middle row seats would operate in a similar way.
  23. Feb 5, 2023 at 4:03 PM
    Pablo58
    Pablo58 New Member
    Paul
    None yet
    edgesalon likes this.
  24. Feb 5, 2023 at 4:44 PM
    esavi87
    esavi87 [OP] .
    Hey! Thank you-that is exactly what was wrong, amongst other things. I traded it up for a 17 ORP, and fixed all my problems! Haha. Stay rad, my dude!
    RumHamRunner73 likes this.
  25. Feb 5, 2023 at 5:49 PM
    Oakboro, N.C
  26. Feb 5, 2023 at 6:42 PM
    Pablo58
    Pablo58 New Member
    Paul
    None yet
    I had the same problem with a 2018 that i purchased just over a year ago. The previous owner yanked on the lever until it broke. I had to spend $65.00 to replace the lever and I am going to fix the cable myself. Not happy
