Metallic "Tink" Sound
Discussion in '5th Gen 4Runners (2010-2024)' started by kami, Mar 28, 2021.
  1. Mar 28, 2021 at 11:28 AM
    kami
    kami [OP] New Member
    I'm at a loss. I've recently installed the Eibach pro lift (I don't think this is related, but maybe you will). Under moderate to hard braking, there's a metallic "tink" sound that comes from the driver's side front. It doesn't happen under easy braking. I've sometimes been able to feel it in the steering wheel, but not always. It's predictable enough that I can recreate the sound on demand, however rocking the vehicle won't reproduce the sound either. At least, not the amount that I'm able to rock it. I thought maybe swaybar bushings or sticky brakes? I haven't noticed any pulling or uneven wear, so I doubt the latter. I had all of the wheels off this weekend and checked every joint, hinge and fitting that I could think of. I'm lost on this one.
  2. Mar 28, 2021 at 1:03 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Have you checked every bolt for tightness?
    I had a sound like that, sometimes could feel it. It ended up being a ever so slightly loose caliper bolt. Couldn't see it was loose until I threw a socket wrench on it.
    JR7 likes this.
  3. Mar 28, 2021 at 1:27 PM
    kami
    I'll give that a shot. Not something I've thought of.
  4. Mar 28, 2021 at 5:16 PM
    thatchtt2001
    thatchtt2001 New Member
    TTT
    Northwest Ohio
    2016 Trail
    Eibach Stage 1 Shocks with OEM Springs.
    It wasn't doing it before the lift? Check the sway bar? I'm sure you probably did....
  5. Mar 29, 2021 at 2:21 AM
    kami
    Yeah, didn't find anything suspect.
    I did not, but the going consensus on here was that the relocation wasn't necessary with the 2.75" that the eibach system gives. Maybe I should be looking at that?
  6. Mar 29, 2021 at 7:18 AM
    JustATallDude
    JustATallDude New Member+
    2019 Toyota 4Runner TRD Pro
    Gibson Single Exit Exhaust - Magnuson Supercharger - Sprint Booster - GTR Ultra2 Highs - Evil Headlights w/ Morimoto LED - Anzo Black Smoked Tail Lights - LED Interior Lights - A-Pillar Phone Mount Mod - CTH Side Mirrors - Eibach TRD Pro-Lift Springs - Falken Wildpeak A/T3s 285/70/17 - FSW F246 17x8.5 - Lasfit LED Turn Signals - DDI Seat Jackers - Apex Overland Front Recovery Points - Big Red's Turn Signal Mod and AMD Mod - R4T Blackout Turn Signals - BlackVue DR590 Dashcam and more to come...
    I'm experiencing the same noises. Even turning sometimes can make a noise. I ordered the Icon relocation kit after the first one didn't fit. Hoping it takes care of it. Only did the lifting springs. Stock everything else.
  7. Apr 7, 2021 at 5:20 PM
    kami
    Checked the brakes... everything's tight. No clearance issues with the sway bar and everything else seems to be in good order. Any other suggestions?
  8. Apr 7, 2021 at 6:39 PM
    thatchtt2001
    TTT
    Northwest Ohio
    2016 Trail
    This is probably stupid but are your lugnuts tight? I can't think of anything else, just throwing dumb stuff out there..
  9. Apr 7, 2021 at 7:02 PM
    ToyotaMacGyver
    ToyotaMacGyver At 88mph you’re going to see some serious sh...
    Justin
    Missouri
    2017 Super White TRD Pro
    What mods have you done?
  10. Apr 8, 2021 at 5:58 PM
    kami
    Just the eibach pro lift and a new set of brakes. I've checked all, to include the lug nuts.
  11. Apr 8, 2021 at 5:59 PM
    kami
    At this point I'm about to just take it to a shop. I'm fairly mechanically inclined, but this has me thrown.
  12. Apr 8, 2021 at 6:20 PM
    ToyotaMacGyver
    Justin
    Missouri
    I’d suspect it to be related to the lift. Sounds like a coil may need adjusted in the spring perch. I’d compare to a factory setup picture for reference and re-torque all bolts to spec. If you haven’t had an alignment since the lift that would be something the shop can do at the same time.
  13. Apr 17, 2021 at 10:34 AM
    thatchtt2001
    TTT
    Northwest Ohio
    2016 Trail
    I just changed out my front springs and was thinking about this noise during the job and thought I would mention the three nuts on top of the shock mount.. I don't think we mentioned those.
  14. Apr 17, 2021 at 4:39 PM
    ThePnsh3r
    ThePnsh3r New Member
    2020 TRDOP
    Are your springs properly seated? Also, simply go over every bolt that you’ve loosened up during the install and check for proper tightness - hopefully with a decent torque wrench.
    Also, as other mentioned - check your sway bars for clearance during compression. If you can find some off pavement terrain - take the vehicle over it at safe speed and see if the clicking is there. That should help you further eliminate it.
  15. Apr 18, 2021 at 4:31 AM
    thatchtt2001
    TTT
    Northwest Ohio
    2016 Trail
    One other thing I had to take off was the skid plate,....
  16. Apr 18, 2021 at 5:09 AM
    ThePnsh3r
    2020 TRDOP
    You could try reseating it. Now that you mention it, I do recall reading about it making such noise. See if I can dig up the post ....
