Master cylinder/brake info on 95
Discussion in '2nd Gen 4Runners (1990-1995)' started by macksrunner, Jan 29, 2021.
  1. Jan 29, 2021 at 2:35 PM
    macksrunner
    macksrunner [OP] New Member
    95 4Runner
    New suspension
    Hey y’all, hoping to get some info ASAP. Need the original part # for the 95 master cylinder. Having trouble finding it and the dealership isn’t any help. Having to replace the whole brake system on my babe. Help please
  2. Jan 29, 2021 at 2:59 PM
    threepointno
    threepointno New Member
    93’ T4R
  3. Jan 29, 2021 at 3:14 PM
    Welcome to the forum.
    macksrunner[OP] likes this.
  4. Jan 29, 2021 at 3:20 PM
    threepointno
    93’ T4R
  5. Jan 29, 2021 at 4:02 PM
    macksrunner
    95 4Runner
    New suspension
    I have it in a shop, it’s originally from Washington state. Haha honestly where do I begin. Last summer I was cut off, slammed on my brakes and lost pressure. Took it to a “friend” who rigged the fu*k out of it. Now about 8 months later it’s back in a shop. A different shop. And having the master cylinder replaced and the rest of the system pressure tested. So haha thanks for the welcome, just want my baby back....
  6. Jan 30, 2021 at 7:55 AM
    ZARTT
    ZARTT New Member
    Art
    1995 4Runner, Black,Tan Interior, 5spd.,(convert from A340) 207,000 mi., on its 3rd 3VZE.
    Ford Taurus 2 spd. elec. cooling fan, GM CS-144 alternator upgrade. Intimidator AGM battery.
    Hi:
    The OEM parts supplier, AMAYAMA, in Japan, quotes the original P/N for a 1995 4Runner, frame # VZN130L, (4 door, auto trans, non 4 whl. ABS) as 47201-34010.
    The part is available for, get this, approx. $390.00, and $35.00 shipping. WOW!!!
    There are 2 other sub numbers listed, 47201-04020 is listed as a substitute for the original, and 47201-3D240 is listed for a car with 4 wheel ABS.
    The numbers are the same for a car with a manual transmission.
    So, try shopping these numbers around domestically, and see whats available in the U.S.
    Good Luck
    Art.
    If you still have the original M/C, you could probably obtain a rebuild kit for it.
    As long as the bore isn't rusty or corroded, maybe a refurb. could be in your future.....?
