Make two wheel drive into 4x4?
Discussion in 'General 4Runner Talk' started by ribish, Mar 5, 2021.
  1. Mar 5, 2021 at 11:18 AM
    ribish
    ribish [OP] New Member
    I have a 2005 4Runner 4x4 with everything in good shape and low mileage ... but with bad frame rust. The most likely "out" for me is to buy a high mileage 2 wheel drive 4runner (because they sell for less) and swap my engine and transmission etc. into it. Can you easily do that to a 2 wheel drive vehicle? Thanks!
  2. Mar 5, 2021 at 11:21 AM
    Welcome to the forum, it’s been done several times.
  3. Mar 5, 2021 at 11:24 AM
    fajitas21
    fajitas21 New Member
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    If you're mechanically inclined enough to do that kind of work I am not sure you'd have to ask if it was doable on a forum.
    I am pretty mechanically capable and that's probably well beyond me.
    Could you? Maybe if you're not in a rush and love learning and just enjoy the process, then sure....I say go for it.
    If it's a daily, or you need in the next 3 months, that's a hard pass.
    Also, and this probably won't matter much, but the VIN, tags, paperwork will always be 2WD and will affect resale, but I highly doubt that's a consideration.
    Last thought, if you're making an offroad beater, you should just finish the evolution and solid axle the front.
    SlvrSlug likes this.
  4. Mar 6, 2021 at 7:03 AM
    markmb45
    markmb45 New Member
    South Ogden, Utah
    2013 4Runner Trail Edition
    3” OME Lift, JBA UCA’s, 275/70R17 General Grabbers, ARB air compressor
    I’ve swapped several 3rd gen 4Runners, 2wd to 4wd. You need access to a lift. Raise the body, roll out the chassis. If you leave the body on frame and swap drive trains you’ll need to swap the wire harness. It can be a lot of work, just take your time.
  5. Mar 6, 2021 at 8:28 AM
    Welcome from Arizona! Anything is possible with time and $$
