Magnuson Supercharge Problem
Discussion in 'Performance' started by sgt100, Jul 31, 2020.
  1. Jul 31, 2020 at 9:56 AM
    sgt100
    sgt100 [OP] New Member
    2019 TRD Off Road
    Magnuson Supercharger
    I have a 2019 TRD off road with a Magnuson supercharge installed. Included with the install a Magnuson reservoir was installed next to the firewall for coolant. The reservoir leaks on both sides at the inlet and exit tubes under the hose clamps. My installer says it is due to ridges on the tubes of the Magnuson reservoir tubes. We have called several times and emailed Magnuson once since the install and so far no response from Magnuson. Has anyone else had this problem and if so how have you corrected it?
  2. Aug 1, 2020 at 7:40 AM
    Welcome to the forum, i hope someone can chime in to help you.
  3. Sep 2, 2020 at 5:41 PM
    mynameistory
    mynameistory New Member
    Tory
    The same 4Runner everyone has
    Don't know if this application is the same as the Tacoma, but someone else reported the same problem.
    Full link here:
    https://www.tacomaworld.com/threads/updated-w-fix-supercharger-coolant-leak-on-the-reservoir.363310/
    Oldtoyotaguy likes this.
  4. Oct 6, 2020 at 5:16 PM
    Jsparr1983
    Jsparr1983 New Member
    2019 TRD PRO Voodoo Blue
    CAI TRD Exhaust Pedal Commander Hood Deflector Oil cap Interior lighting LED Skid plate blacked out Matching spare Baja fog lights Csf racing radiator Apharex luxx with Lasfit switchback headlights Two eagle smoked tail lights with sequential led Glove box and console organizers Ac knob upgrade KC hilites stealth bar Tail lights with Led upgrade Ditch lights Supercharger Rear window controller Ultra swing with lighted license plate and camera relocation Cyclone rock lights Aiden James do light bezels Aiden James gear plate Aiden James under hood light
    Magnuson suggests worm clamps over the typical automotive clamps. I had the same problem and took it back to the installer to swap them all out. Coolant system is under higher pressure.
