Lubing drive shaft question
Discussion in 'Suspension' started by Thacrow, Apr 28, 2024.
  1. Apr 28, 2024 at 3:53 PM
    Thacrow
    Thacrow [OP] New Member
    2021 ORP
    Speed holes
    Looks like there's this smaller nipple inside the draft shaft. Assuming this needs to be lubed but...is there a small attachment t to reach this thing? None of the attachments on my grease gun reaches.
  2. Apr 28, 2024 at 3:59 PM
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    A "needle" attachment would work. The type of attachment for lubing flush fittings.
    gomiami and Thacrow[OP] like this.
  3. Apr 28, 2024 at 4:10 PM
    Thacrow
    2021 ORP
    Speed holes
    Sweet thank you. I shall try the needle. I just converted all the other fittings away from that so I was hoping I'd never need to use the needle again
    2Toys likes this.
  4. Apr 28, 2024 at 6:43 PM
    That’s the u-joint. I can just barely jam the tip of the grease gun in there to grease them. Give a couple pumps until you hear a little crackle sound.
    Toy4X4 and Thacrow[OP] like this.
  5. Apr 29, 2024 at 12:14 PM
    PhantomTweak
    PhantomTweak New Member
    Patrick
    OREGON
    1999 4Runner, bone stock
    TBH, I've never had any trouble getting my grease gun fitting in there to lube those. I have a regular fitting on a flexible hose. I make sure the U joint fitting is straight down, and just slip the grease gun fitting right on in. Light tug to make sure the fitting is on properly. Give it a few pumps, until I get the crackle, and pull the grease gun fitting out again.
    Nothing special. Harbor Freight cheapie. I do all the greasing twice a year. Maybe over do, but it's worked great for me...
    I think the secret is the flex hose on the gun, not a solid tube. Lets the fitting stay locked on without stressing the fitting overly while pumping. Maybe?
    Pat☺
    icebear, Toy4X4, gomiami and 3 others like this.
  6. Apr 29, 2024 at 12:45 PM
    3JOH22A Toyota Gigolo
    One of these two should work lol: https://www.amazon.com/Coupler-Locking-12000PSI-Dispenser-Compatible/dp/B0BQ3B4LB1
  7. Apr 29, 2024 at 12:55 PM
    jharkin
    jharkin New Member
    Jeremy
    Boston suburbs
    2023 Black Pro
    +1, same here the flexible hose on my grease gun fits in there (barely). Are you doing this with the truck up on jack stands and the rear axle fully drooped? Could be the axle is articulated down enough that the angle of the driveshaft is making it tight. Solution would be to turn the shaft 1/4 turn to orient that nipple to the side and open the joint a bit.
    FYI, as others mentioned that's the U-joint grease nipple. The other one next to it on the shaft itself is for greasing the slip yoke.
    Toy4X4 likes this.
  8. Apr 29, 2024 at 12:56 PM
    TRDSD
    2019 TRD Off Road Premium
    Just get a Lock N Lube or knock off version of one for your grease gun. Works with all the zerk fittings.
    gomiami and RumHamRunner73 like this.
  9. Apr 29, 2024 at 7:13 PM
    Thacrow
    2021 ORP
    Speed holes
    I was in fact trying to get to the u-joint nipple with the suspension fully drooped. Unfortunately the grease gun just barely doesn't fit with the car back on the ground. Cant find my needle. Need to order one.
  10. Apr 29, 2024 at 7:15 PM
    Thacrow
    2021 ORP
    Speed holes
    have a couple lock n lube attachments. Doesnt fit. I do have a 3 inch lift on 33's. Couple be angling the drive shaft down juuuust enough to not fit. ordering a needle.
  11. Apr 29, 2024 at 8:48 PM
    Why? Faster and safer to jack it up by the axle.
    Order the kit I linked. That coupler is thinner than Lock N Lube's.
  12. Apr 29, 2024 at 9:13 PM
    Thacrow
    2021 ORP
    Speed holes
    Would that actually change the axle angle? I could throw a bunch of weight in the back......guna try that tmw
  13. Apr 30, 2024 at 3:03 AM
    Turn the shaft and you should be able to find enough room to get on the grease zerk. It's not a big opening.
