Lower control arm Clunk and Squeak
Discussion in '5th Gen 4Runners (2010-2024)' started by Foreverunner, Oct 6, 2022.
  1. Oct 6, 2022 at 9:36 AM
    Foreverunner
    Foreverunner [OP] New Member
    Hello!
    Been chasing a clunk that has been driving me crazy.
    it happens when cornering right while breaking. Also when driing very low speeds. and when turning the wheel left and right while stopped.
    car has 30k miles, it was hit on the driver side in a very minor accident against a light post.
    2.5 inch eiback 5100 front and back and ome installed around the same time.
    so not sure if it's from the accident or the suspension install.
    alignment people left the cam bolts lose, I re torqued them to 150lb problem still there.
    https://youtu.be/Q8huyQ7r8aM
  2. Oct 6, 2022 at 11:17 AM
    Neat view! It sure looks like a lot of movement in the LCA. Is the bolt bent maybe?
    I wonder how much movement the other side would show if you recorded it?
  3. Oct 6, 2022 at 2:59 PM
    Overland WT
    Overland WT Grumpy Old Guy
    Bryan
    West Texas
    2017 TRD Off Road
    Many with many more to go
    Ya, that lateral movement is no bueno.
  4. Oct 8, 2022 at 1:57 PM
    Foreverunner
    I re recorded both sides driving over the same bump (breaking and turning right) from a better angle
    https://youtu.be/0SwxplI0O8c
    https://youtu.be/4VWeP0LXdeY
  5. Oct 8, 2022 at 2:23 PM
    Too Stroked
    Too Stroked New Member
    Tom
    South shore of Lake Ontario
    2021 SR5 Premium
    Toy4X4 likes this.
  6. Oct 8, 2022 at 2:25 PM
    Foreverunner
    both or just the one that seems to squeak more (left one) thats the side that hit a post too.
  7. Oct 9, 2022 at 2:58 AM
    The control arm bushing seems to be the culprit.
  8. Oct 9, 2022 at 4:08 AM
    Too Stroked
    Tom
    2021 SR5 Premium
    Remember, a bushing is supposed to move somewhat. What your video shows though is a bit too much movement. I'd replace the one on the left side. I'd also seriously consider going after your insurance company for "hidden damage" from the crash.
    4runGirl88 and Toy4X4 like this.
  9. Oct 14, 2022 at 6:39 PM
    Foreverunner
    got it. Thx
    took the car to toyota. Service advisor did an inspection and initially suggested its caused by the aftermarket upper control arm.
    i explained the upper control arm was changed in hopes to fix the existing clunk.
    SA will take it to boss and toyota to see what can be done.
    suppose i will continue to record more videos in different places.
  10. Oct 15, 2022 at 9:54 AM
    Too Stroked
    Tom
    2021 SR5 Premium
    Did you show them the videos?
  11. Oct 15, 2022 at 10:31 AM
    Foreverunner
    I insisted. The SA did not want to see them.
  12. Oct 15, 2022 at 11:01 AM
    Too Stroked
    Tom
    2021 SR5 Premium
    Bummer. I'm sure the Service Technician would have found them very helpful.
    Toy4X4 likes this.
  13. Oct 20, 2022 at 4:55 PM
    Foreverunner
    Found the intermediate steering shaft to be making strange noises.
    Apparently it’s not uncommon for them to fail prematurely.
    https://youtu.be/k6SQBBrNGn0
    Thoughts? Does not seem like a normal sound.
    also not sure if it is the cause of the clunk.
  14. Oct 25, 2022 at 11:17 AM
    Foreverunner
    Dealer does not want to fix the issue due to having a aftermarket suspension. I suppose I can fix it myself then. very frustrating.
  15. Oct 26, 2022 at 2:06 AM
    Find another dealership, when you said the SA did not want to see your video...... what tunnel vision! They already knew they were not going to fix your vehicle, and about the intermediate steering shaft, 'it's not uncommon for premature failure'? You mean like loss of steering or noise making? Hope you get it fixed, but seriously, look to another dealership with an open mind.
  16. May 28, 2023 at 8:49 AM
    Foreverunner
    the car has been to the dealership 10 times now in the past 6 months. they added shims in the front suspension (dont know where) claiming the parts where not aligning due to the lift. then asked me to get an alignment.
    I went ahead and changed the lower control arm on that left side. No change.
    currently having the car aligned now.
    Not sure where to go from here.
  17. May 28, 2023 at 5:05 PM
    A different dealer, if it’s been to the same dealer all those times.
    And seriously, it’s not going to be warrantee, so you shouldn’t limit yourself to a dealer. Just find a shop that is interested being payed to solve mechanical problems. In contrast to your dealer…who seem interested mostly in booking appointments. Shit man, I haven’t been anywhere more than 10 times in 6 months, besides home and work.
    Maybe a place that specializes in collision damage, or an off-road shop.
    Idayota likes this.
