Lower ball joint replacement
Discussion in '5th Gen 4Runners (2010-2024)' started by 808stateofmind, Feb 18, 2025 at 2:28 PM.
  1. Feb 18, 2025 at 2:28 PM
    808stateofmind
    808stateofmind [OP] New Member
    Looking for advice on lower ball joint replacement... my gf's 2015 sr5's driver side lower ball joint is shot, so im looking into options to replace both. I've read that toyota considers the lower ball joints non serviceable, and would recommend changing the entire LCA, is this true? Would you change out just the lower ball joint, or replace the entire LCA if you were gonna do it yourself? Also would it be worth the extra money to go oem if you were doing the LCA, or would aftermarket be fine? Might also bang out the upper ball joints and some other suspension components while I'm at it just to freshen everything up... any advice would be appreciated
  2. Feb 18, 2025 at 2:40 PM
    Yes Toyota says to replace the whole LCA.
    I always say OEM because I don't want to waste time if something doesn't fit.
    I don't think they even list a PN for the lower ball joint so even finding aftermarket may be tricky.
  3. Feb 18, 2025 at 3:04 PM
    coachhomer
    coachhomer New Member
    This is such a fun topic because where does it end? Once you get in there, everything could need some fine tuning.
  4. Feb 18, 2025 at 3:11 PM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    Definitely go OEM on all of it.
  5. Feb 18, 2025 at 3:15 PM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered. Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Diode Dynamics 921 XPR Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
  6. Feb 18, 2025 at 3:33 PM
    808stateofmind
    Haha, yup definitely probably opening a can of worms. I've been telling my gf, that it's about that time that she's gonna need to drop some cash if she wants to keep everything going for a lot longer. I'm already looking at lca's, upper ball joints, tie rod ends, and front and back sway bar end links, and that's with just a visual inspection without taking off the tires
  7. Feb 18, 2025 at 3:34 PM
    808stateofmind
    I've seen that moog makes a replacement
  8. Feb 18, 2025 at 4:16 PM
    TrailSpecial22 New Member
    PA
    Go with a Moog whole LCA. IT’ll be worth it.
  9. Feb 18, 2025 at 4:18 PM
    PA
    how many miles did it last. My originals on my 2011 started showing their age at 156k.
  10. Feb 18, 2025 at 4:30 PM
    Startrek
    Startrek New Member
    define "shot". old rubber boots show sign of deterioration. should be inspected annually and boots easy to replace. uppers, lowers and tie rods
  11. Feb 18, 2025 at 4:49 PM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    MOOG has turned into garbage. Not the MOOG of yesteryear.
  12. Feb 18, 2025 at 4:50 PM
    Rocko9999
    2011 Limited
    This. Who said it's shot?
  13. Feb 18, 2025 at 4:55 PM
    PA
    The OP did
  14. Feb 18, 2025 at 5:20 PM
    4onto
    4onto New Member
    Monday
    Toronto
    2009 SR5 V6 4WD
    O.E. lower arms are the best bet. They're the ones I'd be most comfortable with but they're four times the price of aftermarket. But then again, aftermarket arms can cause lots of headaches from squeaking to persistent alignment problems. I've changed out my lower ball joints with Sankei 555 joints but they're hard to change without a ball joint press kit (which I have).
  15. Feb 18, 2025 at 5:40 PM
    808stateofmind
    Her 2015 has almost 90k. Surprised they are worn this fast
  16. Feb 18, 2025 at 5:42 PM
    808stateofmind
    Boot is torn, and flung grease on the inside of the tire and lower control arm. Not sure if the joint are fully blown out, or if I could change just the boots and re grease. Would you use just generic boots?
  17. Feb 18, 2025 at 5:46 PM
    PA
    yep. Weird but only you knownher driving style.
  18. Feb 18, 2025 at 6:52 PM
    Being 10 years old, jack up the front end by the frame to unload the suspension, then check if the cam bolts will turn. If cam bolts are seized, replace only the ball joints. If cam bolts are free to rotate, replace the whole arms.
  19. Feb 18, 2025 at 7:19 PM
    PA
    If the cam bolts are seized, its time to cut them out and replace everything (cam bolts and lca) so you can maintain alignment and get rid of the slop in the lca. I recommend SPC cam bolt kit.
  20. Feb 18, 2025 at 7:39 PM
    No. If cam bolts are seized but the bushings are OK, leave as-is and replace the ball joints in-situ. The SPC cam bolt design is crap - the D-shaped holes round out in short order and cause alignment to drift. OEM cam bolts are designed differently, but quite expensive.
    Of course, replacing the ball joints in-situ takes a bit of work as well. Likely need to heat the LCA with a torch while wailing at the ball joint with a BFH, at least that's what the Toyota specialist shop had to do with mine. Their C-clamp style ball joint press couldn't get it out.
    Rocko9999 and 4onto like this.
  21. Feb 18, 2025 at 7:59 PM
    PA
    interesting about SPC cam bolts. Mine have been on for 4 years and never shifted out of alignment. Maybe people are not torquing them to 150 ft lbs as instructed.
  22. Feb 18, 2025 at 8:08 PM
    Startrek
    Startrek New Member
    OP: if Boot is torn, just replace it. Febest has it.
    808stateofmind[OP] likes this.
  23. Feb 18, 2025 at 8:26 PM
    4onto
    4onto New Member
    Monday
    Toronto
    2009 SR5 V6 4WD
    My C-clamp style ball joint press got them out. I cleaned and lubed the screw with gear oil and used a 40" long 3/4" drive breaker bar. They let go with a CRACK! A 1/2" drive impact gun did nothing.
    Rocko9999 and TrailSpecial22 like this.
  24. Feb 19, 2025 at 3:22 AM
    Gracio
    Gracio New Member
    Blayne
    Cloverdale, CA
    I bought a set of Moog lower control arms not too long ago for my mustang, replaced them myself and took to alignment shop. They had a ton of play in the ball joints, way worse than than the worn out ones I replaced. Talk about a hard lesson learned. I will never buy their Chinese product again, I still have them in Chinese box they came in. I used Moog several year ago before they sold out to China and they were good, not anymore.
    If your considering Moog, simply go out into the garage and beat your head on the wall a few times to save time. Hello
  25. Feb 19, 2025 at 3:29 AM
    PA
    i guess they dont make them like they used to. My 2021 versions were nice a snug, no play. I guess the lesson is, if you can afford the oem from the dealer or reputable toyota parts place, go with them.
    Rocko9999 and 808stateofmind[OP] like this.
  26. Feb 19, 2025 at 6:29 AM
    4onto
    4onto New Member
    Monday
    Toronto
    2009 SR5 V6 4WD
    Rock Auto lists 10 aftermarket lower ball joint choices for a 2015 4Runner.
  27. Feb 19, 2025 at 8:14 AM
    808stateofmind
    I always thought moog was a good aftermarket choice, but I've definitely heard not good things lately
  28. Feb 19, 2025 at 8:15 AM
    808stateofmind
    I bought a new boot, I'm gonna check the ball joint to see if it's still good, and if so just replace the boot for the time being
  29. Feb 19, 2025 at 9:08 AM
    Rocko9999
    2011 Limited
    Didn't even know you could replace just the boot.
  30. Feb 19, 2025 at 9:11 AM
    Cool I don't even look at rock auto because they tried to charge me $500 shipping on brake parts to Hawaii.
