Low Tire pressure warning light on
Discussion in 'Wheels & Tires' started by Timmy4x4, Nov 13, 2017.
  1. Nov 13, 2017 at 9:41 AM
    Timmy4x4
    Timmy4x4 [OP] New Member
    Tim
    when I saw the low tire pressure light goes on I checked the tires and put air in the ones that needed it. The light has not gone off even though the pressure for all the tires are adequate. Is there something else I am not seeing? Is there a way to reset the light so that it goes off? Thanks
  2. Nov 13, 2017 at 9:43 AM
    Bob
    Bob Member Staff Member
    Bob
    Did you check the spare as well?
  3. Nov 13, 2017 at 9:44 AM
    Timmy4x4
    Tim
    is there a sensor in the spare too? Did not know that.
  4. Nov 13, 2017 at 9:49 AM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX4(Runner)60
    There is not a sensor in the spare.
    You have to drive it. After 100 feet or so the light will go off. If it does not then you have a low tire (still) or some fault in the TPMS. The threshold for TPMS to activate is around 28 PSI I believe.
    Bob likes this.
  5. Nov 13, 2017 at 9:57 AM
    Timmy4x4
    Tim
    Usually it goes off when I put air in above 35PSI but this time it hasn't
  6. Nov 13, 2017 at 10:02 AM
    MeefZah
    Lexington, Ohio
    2020 GX4(Runner)60
    Did you drive it? If not, do. If you did, then check the other tires again and especially check the one that was low initially to ensure you don't have a fast leak. If they are all ok then I don't know what to tell you.
    You say "usually". How often do you have a low tire?
  7. Nov 13, 2017 at 12:13 PM
    RonT4R
    RonT4R New Member
    Ron
    Virginia Beach
    2007 4runner SR5 4WD
    Also with the outside temp change you may have to get your TPMS reset. Mine would always need resetting during the climate change of the seasons until I disabled it....
  8. Nov 14, 2017 at 7:24 AM
    macdonaldarchitect
    macdonaldarchitect New Member
    Michael
    How old are your TPMS? My wife's '08 had a battery give out and had to be replaced. I also have had a new TPMS give me intermittant indication of low tire pressure. We couldn't find which one was the faulty TPMS so I finally disabled the TPMS module from info found on this website.
  9. Nov 14, 2017 at 9:49 AM
    jester243
    Dan
    Spokane, WA
    when that happened was it a solid light or did it blink on and off?
  10. Nov 14, 2017 at 9:59 AM
    macdonaldarchitect
    Michael
    jester243 said: "when that happened was it a solid light or did it blink on and off?"
    It blinked for a minute at first and then turned solid. I had a tire shop scan all 5 TPMS and they found one that was not registering. They replaced it and it's been functioning with no light on since then.
    rsimi72 and jester243 like this.
