Low Idle to High Idle
Discussion in '3rd Gen 4Runners (1996-2002)' started by 2runnerRandy, Apr 22, 2025 at 7:55 AM.
  1. Apr 22, 2025 at 7:55 AM
    2runnerRandy
    2runnerRandy [OP] New Member
    Tuesday
    Howdy,
    2001 3.4L Auto, and now experiencing high idle issues after cleaning the throttle body; However, prior to cleaning the throttle body, I could barely get it started and it would not maintain 700-800rpms; the rpms would drastically drop and vehicle die at stops. After cleaning it, it fires right up without assistance, but now I have a high idle issue 1100-1200 rpms when at operating temperature.
    I did replace both Air/Fuel O2 Sensors: Denso Upstream
    I am cleaning the IAC next and hope that does the trick.
    All comments welcome. Thanks, and happy to be here!
  2. Apr 22, 2025 at 8:05 AM
  3. Apr 24, 2025 at 7:35 AM
    You have to drive it for an hour in city traffic to let it relearn. This sounds normal especially if you've disconnected the battery.
  4. Apr 24, 2025 at 7:59 AM
    it needs to relearn as others indicated. Some OBD2 scanners will do that function for you. If not, just drive it around.
