Love our 2023 TRD Pro!
Discussion in 'New Member Introductions' started by betsy, Oct 1, 2023.
  1. Oct 1, 2023 at 5:33 PM
    betsy
    betsy [OP] New Member
    Virginia, USA
    2023 TRD Pro, Ice Cap
    Hi everyone! My husband and I are the proud owners of a new 2023 TRD Pro in Ice Cap white. It looks just like every other white TRD Pro out there, but we love it because it’s ours!
    We did a lot of research leading up to this decision. Our daily drivers are a venerable 2008 Prius (making some rattling sounds but still going strong!) and a 2012 Porsche Cayenne turbo. We were looking for something in between that offered greater cargo capacity with 4WD or AWD. We considered all-electric cars but decided that we aren’t quite ready to make that leap. We also thought about a second hybrid, but our Prius fills the economical commuter car role for us so we didn’t feel compelled to buy another.
    When my husband suggested a 4Runner, I was intrigued! We’ve always owned and liked Toyotas. In particular, I’ve come to appreciate our 2008 Prius because it has been bulletproof in comparison to the Cayenne. The characterization of the 4Runner as the “dinosaur” of the Toyota lineup ironically was a key selling point for me: I fully appreciate the 4Runner’s proven drivetrain and easy-access maintenance.
    We test-drove a TRD Off Road Premium with KDSS and then the TRD Pro. The big surprise for us was that we preferred the handling and ride of the Pro over the ORP with the KDSS. We are very glad we experienced both systems for ourselves and I’d encourage people to drive both types.
    Even though we have no plans to off-road our truck, I am very grateful for this forum and I really enjoy reading about what all of you are doing with yours! I love that the 4Runner comes in so many variants that make it possible for people to modify their truck for their own needs.
    I leave you with a photo of one of our pups who is very excited to be a 4Runner Dog. He is just 5 months old and has a bit of growing to do but he is getting a good start!
    Best wishes to all of you and thank you for your inspirational stories and advice!
  2. Oct 1, 2023 at 5:46 PM
    Dabigono
    Dabigono Just Joined
    2020 4Runner
    Welcome from SoCal
    betsy[OP] likes this.
  3. Oct 1, 2023 at 5:47 PM
    Hyrule_trd
    Hyrule_trd New Member
    Eric
    MD
    2020 Tacoma
    Ironman Foam Cell Pro, MESO stuff, other things I can’t remember
    Welcome to the forums! Nice write up I’ll have to share it with my wife. This is one ONG the SUVs she likes. We’ve been waiting for a Pro to test drive.
  4. Oct 1, 2023 at 6:05 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Congrats OP @betsy and welcome here !
    Heck of an investment and slick ride.
    Ya I have a "pre-ORP" Trail Edition w/ kdss, and I hear the TRD PRO has the best feeling suspension smoothest ride.
    Cheers
  5. Oct 1, 2023 at 6:07 PM
    tundy
    tundy New Member
    ‘23 Pro
    Welcome! I agree on pretty much everything you said, and we reached the same conclusions. It may be a dinosaur but it’s been the best vehicle Toyota makes for a long time.
  6. Oct 1, 2023 at 6:38 PM
    Welcome to the forum, and congrats.
  7. Oct 1, 2023 at 6:39 PM
    betsy
    Virginia, USA
    @Dabigono Thank you for the warm welcome!
    @Hyrule_trd Hope you get a chance to try the Pro. We appreciated the commentary here on the KDSS and it helped us to consider the options. I think it comes down to individual preference and a test drive was the right way for us to make the decision.
    @djwantke Yes indeed it's a significant purchase but knowing how long these 4Runners last helped us to feel more comfortable with it.
    @tundy Hurray for the dinosaurs!
    Hyrule_trd likes this.
  8. Oct 1, 2023 at 7:31 PM
    deltabravo
    deltabravo Livin’ the dumpster life
    East Coast USA
  9. Oct 1, 2023 at 7:49 PM
    DesertSurfer
    DesertSurfer New Member
    Welcome from San Diego!
  10. Oct 2, 2023 at 2:22 AM
    Welcome from Wisconsin!
  11. Oct 2, 2023 at 2:58 AM
  12. Oct 2, 2023 at 3:19 AM
    RusPro17
    RusPro17 Back home again!!
    Don
    Pa.
    2023 TRD Pro Solar Octane
    SCS wheels and Westcott lift
    Welcome! And Congrats!
  13. Oct 2, 2023 at 4:07 AM
    betsy
    Virginia, USA
  14. Oct 2, 2023 at 6:46 AM
    broken-giver
    broken-giver BFD
    congratulations! My favorite color, love the black wheels contrast with white.
  15. Oct 2, 2023 at 6:47 AM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Congratulations! Welcome to the club
  16. Oct 2, 2023 at 8:11 AM
    True, if its for my family it would be 3rd vehicle that can be used on clear days / non winter storm days, vs with our 4Runners we don't care even if we have closer to feet of snow. I've taken my kiddo to doctors on such days and glad we have 4Runner.
    If 4Runners go turbo route with 6th gen I would probably start going hybrid route with lease if we ever have to replace our 4Runners. Since lease will have to keep them stock. So offroading may not be a good idea for a leased vehicle.
    Other than the comfort of thinner sway bar allowing suspension to work more freely you will also appreciate the reliability of having a non hydraulic fluid sway bar.
    We also have a Limited for 99% city use. Absolutely love the reliability and don't have to worry about the weather or even curbs and what not. (We have 17in wheels and tires on our Limited)
    4Runner is the best for dogs imo. Every time I take my doggo I crack the glass down a little. I do have a low profile fan plugged in to the 12v outlet in the back for good air circulation.
  17. Oct 2, 2023 at 10:10 PM
    Pentangler
    Pentangler Happy Member
    Welcome to the family.
  18. Oct 3, 2023 at 4:08 AM
    betsy
    Virginia, USA
    @broken-giver Yes, we think the white looks pretty sharp against the blackout logos. Thank you!
    @hossler1788 Thanks for the warm welcome!
    @kmeeg We read many comparisons between KDSS and non-KDSS (X-REAS?) suspensions, but not a lot about KDSS vs the Pro suspension. For us the decision was based on the feel of the truck in motion, but I'm interested in more on how the Pro suspension differs.
    @Pentangler Thank you so much! It does feel like a family here and we appreciate it.
  19. Oct 3, 2023 at 4:10 AM
    RusPro17
    Don
    Pa.
    The mod fever will hit soon as your on here for a while. Lol.
  20. Oct 3, 2023 at 4:46 AM
    betsy
    Virginia, USA
    Oh we're already starting. Right now we're agonizing over what kind of cargo area protection we should get. Husky or WeatherTech or one of the odd-named brands -- the debate is eternal. One brand also offers armor plates (so to speak) for the back of the second-row seats. We have scraped up the back of our seats in the other cars by shoving cargo forward from the back, so this idea has some appeal. (I know cargo trays don't exactly count as "mods" but bear with us!)
    We've also noticed that our car has the older style of Pro wheels instead of the newer design, and that the old style is cast while the newer style is flowed (not sure what that means) which some have characterized as an improved manufacturing technique. But I checked prices and noted that the old wheels are more expensive than the newer ones. If the new wheels are an improvement I would have expected the opposite. Why would this be?
  21. Oct 3, 2023 at 5:22 AM
    RusPro17
    Don
    Pa.
    I would go with canvasback for the protection in the back. Yes a little expensive but very nice. I’m doing another set because I had them in my 20 AG. Great also cause of dogs which I see you have and so do we. One issue you will find with the new Pro wheel is there is over 2400 center caps on back order. The wheels are available but who knows when the caps will come available. My 23 SO has the older wheel which I wanted the new wheel because my 17 and 20 had the older wheel. But that will be taken care of soon because of Toyota customer service I spoke with a real nice woman who is really helping me out. I will know soon about the new wheel.
  22. Oct 3, 2023 at 1:56 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Its like toyota is putting the old trd wheels on and hoping the buyer won't notice.
  23. Oct 4, 2023 at 3:28 AM
    betsy
    Virginia, USA
    Thanks so much @RusPro17 ! We're ordering the Canvasback!
    RusPro17[QUOTED] likes this.
  24. Oct 4, 2023 at 3:29 AM
    betsy
    Virginia, USA
    Thanks, @hossler1788 . We certainly didn't notice at the time of purchase. It's only from reading this forum that I saw the info about the new wheel design. May I ask if the new wheel is substantively better than the previous version?
  25. Oct 4, 2023 at 6:24 AM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Flow form is probably a bit stronger, I believe the wheels are also lighter.
  26. Oct 4, 2023 at 2:04 PM
    betsy
    Virginia, USA
    Thank you for that information! I appreciate you and all the other helpful folks here.
  27. Oct 5, 2023 at 6:39 AM
    UofLCardfan77
    UofLCardfan77 Large Member
    Elizabethtown, Kentucky
    Welcome from the center of the bourbon universe.
  28. Oct 21, 2023 at 9:41 PM
    makritz
    makritz New Member
    Matthew
    Welcome! We're twinning.
  29. Oct 22, 2023 at 2:06 PM
    Ironguy New Member
  30. Oct 25, 2023 at 2:26 PM
    steelevo
    Utah
    Welcome and congrats
