Lost 10mm socket in 5th gen engine bay: how do I retrieve it?
Discussion in 'General 4Runner Talk' started by SROak, Jul 9, 2024.
  1. Jul 9, 2024 at 10:10 AM
    SROak
    SROak [OP] New Member
    2023 LTD
    none
    I'm a new guy with a 2023 4R Limited. I disconnected the battery (for some electrical mods) and to get at that battery clamp nut I didn't put the 10mm socket all the way on the wrench. So when I lifted the wrench out the socket dropped down the gullet and bang! it hit the under-engine shield. I crawled under and discovered the fine steel plating Toyota protects my truck with, but I can't find any access to retrieve that socket. It looks like I need to remove that entire shield, is that true? Any suggestions?
  2. Jul 9, 2024 at 10:14 AM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    magnet stick - and start sweeping.
    LCJ77 and T in Texas like this.
  3. Jul 9, 2024 at 10:17 AM
    Acesandeights
    Acesandeights #34
    So Oregon
    2024 ORP
    You don't. The 10mm socket is always lost. Everyone loses the 10mm. Look it up.
  4. Jul 9, 2024 at 10:39 AM
    Just pop the shield off. It's practice for when you go to change the oil.
  5. Jul 9, 2024 at 10:41 AM
    SROak
    2023 LTD
    none
    Thanks, I deserved that.
    I've always lost 13mm sockets (VW), but now I know why the 10mm is a meme...
    Acesandeights likes this.
  6. Jul 9, 2024 at 10:45 AM
    I think you need to pull the entire engine out. Gives you experience.
    LCJ77, scottiezilla, Noodles and 4 others like this.
  7. Jul 9, 2024 at 10:54 AM
    Acesandeights
    Acesandeights #34
    So Oregon
    2024 ORP
    I keep a 10mm on my keychain...you just never know.
    TrueTexas and scottiezilla like this.
  8. Jul 9, 2024 at 12:28 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    OP did you start this thread because of the 10mm socket trope?
  9. Jul 9, 2024 at 12:39 PM
    2016Pro
    Sell the truck and move on
  10. Jul 9, 2024 at 1:21 PM
    BearBio
    BearBio New Member
    Greg
    2019, Dark Blue SR5
    Roof rack, side bars
    10mm and 12mm!!!!!!!!!
    I keep several of each around.
    Thacrow likes this.
  11. Jul 9, 2024 at 2:44 PM
    TrailSpecial22 New Member
    PA
    gone forever to the Toyota Gods…
  12. Jul 9, 2024 at 3:10 PM
    SROak
    2023 LTD
    none
    Okay! So the sweep didn't work, so then I bought a crate of 10mm sockets, pulled the shield, yanked the engine out, put a 10mm on my keychain and then put an ad on CraigsList to trade all of this for a 1994 Explorer sh!tbox. I really liked the 4R but Toyota experts can't be wrong...
  13. Jul 9, 2024 at 3:16 PM
    Acesandeights
    Acesandeights #34
    So Oregon
    2024 ORP
    Now that you have a Furd, it'll probably use SAE instead of metric, so you have that going for you! T'were me, and it isn't, I'd also invest in a telescoping magnet:
  14. Jul 9, 2024 at 3:19 PM
    Grandpawmoses
    Grandpawmoses Dirty Old Man
    David
    2024 4R TRD Pro
    Too poor to buy anything now
    Just buy another 10 mm socket. While you're at it, pick up a 10 mm deepwell socket too.
    Thatbassguy and Acesandeights like this.
  15. Jul 9, 2024 at 3:25 PM
    SROak
    2023 LTD
    none
    Now that would have helped prevent the problem
    Got one, and didn't work. For some mystical reason it kept sticking to items of unknown material in my engine bay.
  16. Jul 10, 2024 at 7:50 AM
    wingo
    wingo *****
    2020 Venture
    Use a bore scope to locate it then use a magnetic stick to retrieve it. You can rent a bore scope from Autozone.
    SROak[OP] likes this.
  17. Jul 10, 2024 at 8:51 AM
    Acesandeights
    Acesandeights #34
    So Oregon
    2024 ORP
    That "unknown" material is metal ;)
  18. Jul 10, 2024 at 9:56 AM
    PhillySilver
    PhillySilver New Member
    Silver 2020 ORP
    I have had luck with compressed air or water to move the dropped item to where the pan drains. Some have holes, some have open corners but I have yet to see one that doesn't have some way to drain trapped water. Doesn't work all the time though. It is amazing to me that things you drop and absolutely positively don't want to hit the ground always do and the things you drop that you very much want to hit the ground never do.
    djwantke, LastRide and Acesandeights like this.
  19. Jul 10, 2024 at 10:12 AM
    Schlappesepple
    Schlappesepple New Member
    2020 ORP
    Pull the damn skid plate...
    You could have had it off and back on in the time you've been posting.
    Unless you've also lost your 14(?) mm sockets
  20. Jul 10, 2024 at 10:13 AM
    Schlappesepple
    2020 ORP
    Or turn the truck on it's side, and the socket should just roll off the edge of the skid.
    Thacrow, djwantke and Acesandeights like this.
  21. Jul 10, 2024 at 10:17 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel kit (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-675v Springs) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Delete DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. Custom High Clearance Fender Liners *Coming soon Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: LFD Cross-Bars Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered, coming soon Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights OVS Nomadic 6.5' Awning AVS Low Profile Vent Visor AVS Bugflector II Diode Dynamic puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Finally. I was waiting for a comment like this.
  22. Jul 10, 2024 at 10:50 AM
    I came for the jokes, and I was not disappointed!
    :rofl:
    Thacrow, TrueTexas, djwantke and 2 others like this.
  23. Jul 10, 2024 at 11:32 AM
    @SROak , I'll go with @Schlappesepple on this. I don't know how many bolts there are, but it might not be much work. I wouldn't like having a loose socket rolling around down there.
  24. Jul 10, 2024 at 11:54 AM
    backpacker
    backpacker New Member
    2023 TRD ORP
    I think it's five little ones on the plastic plus the plastic trim clip, then four bolts on the skid plate. For me the hardest part of the process getting back up off the floor when it's done.
    BGH2023 and Thatbassguy[QUOTED] like this.
  25. Jul 10, 2024 at 11:57 AM
    Lol! I know this feeling!
  26. Jul 10, 2024 at 12:01 PM
    backpacker
    2023 TRD ORP
    Also, for this operation it's not necessary to remove the skid plate entirely. Just let hang from the two metal hooks after gently lowering the back end. That will save some re-installation work.
  27. Jul 10, 2024 at 12:21 PM
    MisterFlabby
    MisterFlabby Certified Dumbass
    Matthew
    Ontario, Canada
    2024 Underground 4Runner SR5
    Your 10mm?? No no I believe you meant to say The 4R’s 10mm. You don’t own the vehicle, it owns you!
  28. Jul 10, 2024 at 3:25 PM
    LastRide
    LastRide New Member
    2024 Limited - Classic Silver
    Yes, it is an immutable law of nature. Another is: The older you get, the further things bounce when you drop them.
  29. Jul 10, 2024 at 3:34 PM
    backpacker
    2023 TRD ORP
    They always end up in a place where they can't possibly be.
  30. Jul 10, 2024 at 4:38 PM
    I keep several of each on the skidplates
