Lord help me figure out wtf the issue is
Discussion in '4th Gen 4Runners (2003-2009)' started by Jasmine, Dec 29, 2024.
  1. Dec 29, 2024 at 11:42 AM
    Jasmine
    Jasmine [OP] New Member
    Jasmine
    2007 RUNNER
    Hi all!! I’m experiencing some issues with my 2007 runner. It first gave off a battery code, put in a new alternator, did the starter while we were at it. Still nothing. Bought a new computer, installed new grounds, still won’t turn over. The fuse on the interior drivers for a starter won’t register as getting power. Took the whole box out and cannot figure out how to get into it. Hoping, someone has a suggestion! A wiring diagram to go with it would be soooo helpful!
  2. Dec 29, 2024 at 6:14 PM
    Stuck CAPS
    Stuck CAPS Truck killer
    Alex
    2007 Nautical Blue Metallic Limited V6 4x4
    ARB Bumper, Some Stuff, Some Other Stuff, and some Stuff.
    Have you verified the ignition switch functions as intended?
  3. Dec 30, 2024 at 3:04 AM
    Welcome from Wisconsin!
  4. Dec 30, 2024 at 4:22 AM
    welcome
  5. Dec 30, 2024 at 5:49 AM
    grumpy 02
    grumpy 02 New Member
    Stan
    Colorado Springs, CO
    2007 White 4Runner SR5
    None Yet
    If you are going to fix this your self, I think you need a copy of the Factory Service Manual & quite likely the Electrical supplement as well. Electrical is hard. (for me at least) There are certain troubleshooting procedures that need to be followed, in order, to figure out what is going on. Or make friends with an automotive electrical expert. Sorry I can't be of more direct help.
  6. Dec 30, 2024 at 6:05 AM
    Photon_Chaser 49787 and counting…
    Sierra Nevada Mountains and the Central Coast
    This
    Also, have you checked for power to the starter solenoid, not the main (high current) 12V cable.
    also, see if this will suffice for a manual
    and welcome to the forum!
  7. Dec 30, 2024 at 6:06 AM
    gkomo
    gkomo New Member
    San Diego, CA
    2014 Tacoma AC 4x4
    Have you verified your battery is good? You didn’t give any info on it, unless I missed it.
  8. Dec 30, 2024 at 6:48 AM
    You wheeled in the parts cannon and fired it. Cut your losses and take it in. You tried I get it. I’ve been in your situation and it sucks but throwing parts at it can get expensive
  9. Dec 31, 2024 at 3:22 PM
    I sprayed a can of WD-40 in the key hole. Didnt seem to effect anything. Maybe the key is worn out?
  10. Jan 1, 2025 at 6:54 AM
    Ralph Blake
    Ralph Blake New Member
    2008 sr5 4runner
    Random codes popping up have caused people more money trying to solve them, when the truth is there is nothing really wrong.
    If you can start your truck and it will drive normaly i would just wait and see if anything is really wrong.
    Just quickly replacing everything as you now see solves nothing.
    My feelings are Toyota is doing all it can to push people into their dealer stealer non service Dept's.
  11. Jan 1, 2025 at 6:57 AM
    RepentOrPerish
    RepentOrPerish New Member
    4thGenv8
    One of my keys is worn to the point that it wont open the glove box. So this does happen..
  12. Jan 1, 2025 at 7:42 AM
    AuSeeker
    AuSeeker Old As Dirt
    Skip
    South Carolina
    2004 Limited
    What color is the key that won't open the glove box, gray or black?
  13. Jan 1, 2025 at 8:19 AM
    RepentOrPerish
    4thGenv8
    Both my keys are black
  14. Jan 1, 2025 at 8:31 AM
    AuSeeker
    Skip
    South Carolina
    2004 Limited
    Ok just checking, the gray key is a valet key and they won't unlock the glove box which some owners are not aware of.
  15. Jan 1, 2025 at 8:50 AM
    I remember my 2000 came with two black and one grey keys. After more than 380,000 miles the keys were so worn down that they started jamming in the ignition switch….had to wiggle em a bit to fully go in.
    LOSTR4 likes this.
  16. Jan 1, 2025 at 1:15 PM
    Grandpawmoses
    Grandpawmoses Dirty Old Man
    David
    2024 4R TRD Pro
    Too poor to buy anything now
    Need bikini pics to help diagnose the problem.
  17. Jan 13, 2025 at 4:52 PM
    RonT4R
    RonT4R New Member
    Ron
    Virginia Beach
    2007 4runner SR5 4WD
    Make sure you are not using the valet key…….2007 keys has a chip for the ignition. Keep it simple, do not overthink the problem.
