looking for tire suggestions to replace the OEM junk tires.
Discussion in '5th Gen 4Runners (2010-2024)' started by Dave97, Jan 5, 2025.
  1. Jan 5, 2025 at 4:50 AM
    Dave97
    Dave97 [OP] New Member
    My wifes 4runner 4WD came with the well know Grandtrek AT20 is Dunlop's Size: 265/70R17. They have 30,000 miles on them i am cheap so have been putting off on replacing them as they still have decent tread but i see they are rated really bad in snow.
    We live in VA and rarely get snow anymore but it does happen seems to always be snow/ice mix but 100% of the time the 4runner only sees blacktop and gravel roads.
    In the past my go to tire has always been the Michelin - Defender but i feel like it is to tame for a 4runner, i always bought them because they lasted 60,000 miles. :)
  2. Jan 5, 2025 at 5:10 AM
    bassist
    bassist New Member
    2023 TRD Offroad Premium
    BFG AT KO2 (or KO3).
    Good enough tire so that you can kick it up a notch and have more fun than you are currently having!
    While I need to get back to proper off-roading, they work fine on pavement and on the gravel roads.
    They’ll hold just enough gravel to remind people not to tailgate when you go from gravel to tarmac.
    I’m in VA as well, but they served me well in WI too.
    captrussia253, Shredder and BC Hunter like this.
  3. Jan 5, 2025 at 5:15 AM
    icebear Recovered Kia Owner
    BFG Trail-Terrain, the next step up in off-road looks and performance without going full all-terrain
    Edit: The Defender LTX M/S I believe was discontinued in our fitment but the M/S2 seems a smidge more aggressive so perhaps that or the A/T2?
  4. Jan 5, 2025 at 5:42 AM
    Strongarm
    Strongarm New Member
    2023 4Runner
    I’ve ran the Michelin LTX m+s on my 2001 4Runner, and loved the ride. they replaced 75,000 mile BFG K02s. I went to Michelin because of more highway driving and softer ride.
    When replacing my Bridgestone Duellers on my 17 I went with the load range C BFG K02s to stiffen up the ride. I didn’t like the wishy washy feeling of the 5th gen and knew that they would last.
    I would strongly caution on load range E tires if you don’t carry a lot of weight or off road a lot.
    There are a lot of BFG haters here, but they last a long time, and are pretty durable, capable, and look decent.
    RumHamRunner73 likes this.
  5. Jan 5, 2025 at 5:47 AM
    4Daughters
    4Daughters It’s how I know God has a sense of humor
    Ken
    Powder Springs, Ga
    2022 TRD ORP; Silver; too many port options...Ah well...
    TBD
    I replaced the Dunlops at 35,000 miles with Michelin Defender LTX m/s2. Had to be real about 99% of my driving being on pavement. The Defenders do well enough off road though. M/S 2s are a smidge more aggressive than last generation, and not as quiet as the marketing material leads you to believe. Note: there is no SL rating but rather XL. They are noticeably firmer than an SL tire. I’ve taken them back to Discount Tire twice with fine balancing issues. Dunlops were smooth for 35k; why can’t these high-dollar tires also be smooth? My runner-up choice was the Cooper Road & Trail. Having a bit of buyers remorse, honestly.
  6. Jan 5, 2025 at 5:49 AM
  7. Jan 5, 2025 at 9:44 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    Another tire thread.:facepalm:
  8. Jan 5, 2025 at 9:53 AM
    Charlievee
    Charlievee Not new member.
    Oh boy.
    djwantke likes this.
  9. Jan 5, 2025 at 10:06 AM
    BC Hunter
    BC Hunter New Member
    Paul and Jane
    Kootenays BC Canada
    2024 TRD Pro-Terra
    Stock so far…..
    The KO2s are good all-around tires, and they can be purchased in OEM size as "C" rated, which will be stiffer than your Dunlops, but not significantly.
    [edited: the KO3 is only available in load range "E" , at least in Canada in the OEM size. My guess is those might be more than you want]
    In the KO2, you can also get a LT255/75/17C which is a tiny bit larger in diameter, and a smidgen narrower, and doesn't have the raised white letters.
  10. Jan 5, 2025 at 10:11 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Hey @Dave97
    You’re right Michelin is too tame. Even some Cooper and Continental are kinda tame. Everyone has BFG’s - which I don’t like, and they aren’t the best choice for my region.
    If you want a long lasting tread, highly regarded, snow rated tire, that is as aggressive looking as KO2/3’s, I got two words for you:
    Mickey Thompson.
    Another two words: Baja Boss
    I guess I had 4 words for you.
    Goodluck!
  11. Jan 5, 2025 at 10:15 AM
    Ripper238
    Ripper238 New Member
    2019 TRD OR
    You answered your own question, go with Michelin Defender since you like them and they would fit your needs.
    I personally wouldn't go with any Michelin tire on a "truck" but i need versatile off road besides wet and snow capabilities.
    IMO Goodyear Duratrac RT's are the best all around tire by far, but way overkill for your needs.
    MEski4x4 and djwantke like this.
  12. Jan 5, 2025 at 10:57 AM
    Dave97
    I run Duratracs on my truck way overkill for the 4runner.
    Ripper238[QUOTED] likes this.
  13. Jan 5, 2025 at 11:20 AM
    orcking
    orcking New Member
    Ltx/ms or ms2 for everyday driving.
  14. Jan 5, 2025 at 11:26 AM
    Are they overkill tho if in turn they’re an excellent investment w/ very high mileage output if you’re already buying decent tires. Once in a while you need the extra grip, they’re there for you. In the event of a tie, the guy with AT’s on his 4R gets the lady every time.
    Ripper238 likes this.
  15. Jan 5, 2025 at 11:39 AM
    garoto
    garoto New Member
    I'm very happy with my Falken Wildpeak AT4Ws
  16. Jan 5, 2025 at 12:36 PM
    KilluFirst
    KilluFirst New Member
    '21 Venture MGM
    KO2, RCI Skid and filler plate, Caliraised ditch lights, seat jacker clones, aluminum oil filter housing and fumoto drain.
    ANY kind of grade and I would avoid ko2's like the plague. Huh kinda rhymes. I live in the mountains with ice covered gravel and blacktop. We don't go anywhere when the roads are like that
  17. Jan 5, 2025 at 1:01 PM
    vthoky New Member
  18. Jan 5, 2025 at 1:20 PM
    Acesandeights
    Acesandeights #34
    2024 ORP
    BFG or Michelin
    I won't buy Cooper or Goodyear, had too many issues with crappy and uneven wear. Falken and Toyo became big(ger) names and the price went up and over the value. They're an big sticker without big performance.
    So, for 100% street, Michelin is the right choice.
  19. Jan 5, 2025 at 3:49 PM
    Dave97
    Maximumdarkside likes this.
  20. Jan 5, 2025 at 3:54 PM
    Dave97
    I bought the DuraTracs for the snow and they have have been amazing on my old Tacoma getting me out of some nasty places. It's really the only time i drive it is in bad weather.
    Ripper238 and djwantke[QUOTED] like this.
  21. Jan 5, 2025 at 4:06 PM
    Nice, right on! I wish I had a pick up too.
    Funny enough, I bought Duratracs in ‘21, but supply chain crap delayed my delivery so long that my 4x4 shop advised I pull the plug cuz eta switched to indefinite…switched to Mickey Thompson and never looked back
    Dave97[QUOTED][OP] likes this.
  22. Jan 5, 2025 at 5:22 PM
    catbrown357
    Tempe
    2011 Limited 4WD
    I find it hilarious that people buy tires for how they look.
  23. Jan 5, 2025 at 5:34 PM
    bassist
    bassist New Member
    I used to run super swampers back in the day.
    Loved how the looked. Loved how they performed offroad.
    Loved how I couldn’t hear my engine at freeways speeds and how it turned my seat into a vibrating massage.
    Steely123 and icebear like this.
  24. Jan 5, 2025 at 5:48 PM
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    When I put my ultra terrains on my runner, it looks way better than the OEM highway tires. I didn’t buy them based on looks, but it has an impact.
    Pentangler likes this.
  25. Jan 5, 2025 at 5:58 PM
    coachhomer
    coachhomer New Member
    This
    BC Hunter likes this.
  26. Jan 5, 2025 at 6:05 PM
    Spare Parts
    Southern Maine
    22 LR ORP
  27. Jan 5, 2025 at 6:16 PM
    Imdav2u
    23 TRD PRO
    We have sleet and snow here in the St. Louis area, my stock Nitto Grapplers are very impressive.
  28. Jan 5, 2025 at 7:24 PM
    garoto
    garoto New Member
    If I have two tires that perform very well. Identical. I’d choose the one that looks better.
    I like that the AT4Ws perform excellent and look fantastic.
  29. Jan 6, 2025 at 3:42 AM
    My OR wheels came with brand new Dunlop AT20s. So didn't really need to replace them right away. But after 2 years, they don't handle worth shit as they wear down. They slip in the rain and on gravel roads. Plus they are a f.n magnetic for nails and screws. Lol
    I read too many balancing issue stories on here about KOs. So narrowed down my choice to pirelli scorpions ( that's just basing my experience with pirelli being one of the best sport performers on cars) and Falken wildpeaks. Michelins are always solid performance tires, no experience with them on trucks.
  30. Jan 6, 2025 at 5:25 AM
    Dave97
    looks are a big part of it. IE if they look tame or aggressive.
