Little kokua,please.
Discussion in 'General 4Runner Talk' started by nalu21, Mar 19, 2021.
  1. Mar 19, 2021 at 11:29 PM
    nalu21
    nalu21 [OP] New Member
    2000 4runner SR5
    Aloha from Maui. I need to replace the hatch door key cylinder.Can I just remove the molding around the license molding or do I need to remove the panel inside the hatch door? Napa wants $142.00 for a new cylinder,too much?fullsizeoutput_1018.jpg
    j4unner likes this.
  2. Mar 19, 2021 at 11:42 PM
    36tacundra
    36tacundra New Member
    Its got to come out from the inside. One 10mm bolt holds it in along with the plug. Start by removing the plastic cover at the pull down handle. After the cover is removed a 10mm bolt can be removed. Then the plastic panel can be popped of the door at the bottom working around to the top. Then it is slid up to be removed. There will be wiring and small access panels that also take 10mm. Take your time. Its kind of like working upside-down with the door open.
    nalu21[OP] likes this.
  3. Mar 20, 2021 at 12:19 AM
    nalu21
    2000 4runner SR5
    Thanks alot! I was ready to go in from outside.Really appreciate your help. If you ever come to Maui,the Mai Tais are on me!
    36tacundra likes this.
  4. Mar 20, 2021 at 4:01 AM
    Mohoman
    Mohoman New Member
    Sean
    99 Limited
    Queen of Battle
    Welcome from Austin! Hopefully you got everything taken care of!
  5. Mar 20, 2021 at 9:03 AM
    Welcome!
  6. Mar 20, 2021 at 9:19 AM
    Welcome to the forum.
  7. Mar 23, 2021 at 9:37 AM
    Saitama
    Saitama New Member
    Steve
    San Francisco
    Stock 20 ORP
    Prinsu Full Length Rack, BFG K02's, Midland MXT275
    Aloha and welcome to the forum from the mainland!
  8. Mar 23, 2021 at 9:26 PM
    j4unner
    j4unner shootz brah..
    j4runner
    nCal
    21 SR5P
    aloha from the bay..
