Limited Xreas Replacement Question
Discussion in '5th Gen 4Runners (2010-2024)' started by josephp732, Feb 26, 2022.
  1. Feb 26, 2022 at 6:33 AM
    josephp732
    josephp732 [OP] New Member
    2019 Silver Limited, 2021 White TRD OR Premium
    I am going to be replacing the X-REAS shocks on my 2019 Limited. I am thinking of going with Bilstein 5100's. I did a 5100 upgrade on my 2021 TRD and kept the factory coil-overs which worked out nicely.
    My question is does the X-REAS coil-overs use the same factory springs as the TRD OR? Would I get the same results if I reuse the X-REAS coil-overs as I did with the TRD? Or do I need to also order a set of TRD OR springs?
  2. Feb 26, 2022 at 7:58 AM
    MAXIM
    MAXIM New Member
    I replaced my X-REAS and used factory springs with 5100's with great results.
    josephp732[OP] likes this.
  3. Feb 26, 2022 at 8:08 AM
    As far as I understand if you need any lift in the back you should use a longer spring or spacer on top of the stock spring. I could be wrong, check with a 4x4 shop. I used a spacer in the rear with Bilstien5100.
    Just keep in mind Bilstien5100 with not be comfy as XREAS.
  4. Feb 26, 2022 at 8:47 AM
    josephp732
    Thanks! Yes I know the ride will be different - I am looking to get a ride similar to my TRD OR. That's why I am wondering if the factory coil-over springs - spring rates are the same for a TRD OR and a Limited with X-REAS. I am also going to do a slight .8" front level.
  5. Feb 27, 2022 at 7:06 PM
    weB3jammin
    weB3jammin New Member
    Isaac
    2011 4Runner Limited
    Bilstien 5100 .85"
    2011 Limited
    I replaced XREAS with 5100s set at .85" and it rides fantastic. I have stock springs and I couldn't be happier for a daily setup that is 80-90% on the road. It's a very comfortable, and was a big improvement over my leaking XREAS.
