Lifting advice
Discussion in '5th Gen 4Runners (2010-2024)' started by Sybo, Oct 27, 2023.
  1. Oct 27, 2023 at 2:36 AM
    Sybo
    Sybo [OP] New Member
    Planning on installing Bilstein 5100 on all 4 corners. I want to lift 1.75" in the front and install a 1.5" Rancho spacer in the rear . I do not go off road, I just like the look . Should I have any concerns with this plan ? Thank you for advice and thoughts in advance .
    Opps, forgot to mention I'm working on a 2018 4Runner SR5 Premium.
  2. Oct 27, 2023 at 4:28 PM
    This article may help you: https://www.gorancho.com/blogs/rancho-performance-suspension-101/spacer-kits-vs-suspension-lift-kits
    ADVANTAGES OF SPACER LIFT KITS
    • Works with Existing Coil Springs and Struts – A spacer kit works with factory and coil springs and struts.
    • Easy to Install – Installing spacers is less complicated and takes less time than overhauling the suspension system. You don’t need to disassemble the strut and it doesn’t require the use of a coil spring compressor.
    • Bigger Tires and Wheels – Spacers can accommodate larger tire and wheel setups.
    • Less Expensive – With fewer components, this is an economical option that can fit in a smaller budget.
    • Preserves Factory Ride – Since a spacer kit retains the factory coil springs and struts, the vehicle maintains a similar ride to stock when installed correctly.
    • Economical Solution – A spacer lift kit is an economical solution to level a vehicle equipped with coil springs.
    DISADVANTAGES OF SPACER LIFT KITS
    • Limited Amount of Lift – Because there is a limit as to how high the vehicle can be from the frame, spacer kits only let you raise your vehicle a few inches while retaining CV angles within OE specs.
    • Doesn’t Change Spring Rate – With no change in spring rate, there won’t be any change in the ride of the vehicle. Please note that if you put a larger tire on a stock coil, the coil and shock aren’t tuned for the added tire size.
    • Increased Wear to Components – Many taller lifts can max out the travel of ball joints, tie rod ends and CV joints, which may cause damage to joints, steering knuckles and steering rack.
    • Topping Out – Taller lifts can cause harsh “topping out” when components reach extent of their design travel.
    BOTTOM LINE
    A spacer kit is a great option for getting a small lift on your truck or SUV without altering ride quality. It can be ideal for a daily driver vehicle that is occasionally driven off-road. Use a spacer kit to sit a bit higher for a better view or for the ability to put larger tires on your vehicle. A spacer kit can also raise the nose of the vehicle to give it a more level stance. Taller spacer lifts are more suited to solid axle vehicles where you don’t have issues with overextending other suspension components.
  3. Oct 27, 2023 at 4:47 PM
    Nevin
    Nevin New Member
    Puyallup, WA.
    2022 TRD ORP
    PPF, Tint, Black out badges/Valances. Bilstein 6112's & 5100's
    1.5 is too much lift in rear @ 1.75 front
    CRasch505 likes this.
  4. Oct 27, 2023 at 7:42 PM
    CRasch505
    CRasch505 New Member
    Chris
    5th Gen 4Runner ORP
    Fifteen52 Analog HD's, Nitto Terragrapplers, 1" spacer lift front, ceramic on all glass.
    I think the spacer is ok if you're not looking to do serious off-road with it. As mentioned by @Nevin though, that 1.5 isn't going to give you a level setup. It's still going to be raked, just taller. If you're good with that, go for it. Post pics when you finish!
  5. Oct 27, 2023 at 8:28 PM
    HazOpRed
    HazOpRed 22' TRDOR
    Just buy the springs for the rear, they're not much more than the spacer
