Lift to fit 295/70/17
Discussion in '5th Gen 4Runners (2010-2024)' started by Loganbotts1, Jan 13, 2022.
  1. Jan 13, 2022 at 2:48 AM
    Loganbotts1
    Loganbotts1 [OP] New Member
    Logan
    2016 4runner
    Hey there, so I have a 2 inch spacer lift on my 4Runner and am running 285/65/18. And I want to fit 295/70/17. Is there anyway I can just get a 1 inch body lift to make those tires fit? Need some help. Thanks
  2. Jan 13, 2022 at 7:01 AM
    @Thatbassguy is your man to take advice. He got 295/70R17 and having fun on trails.
  3. Jan 13, 2022 at 7:49 AM
    You're going to need to remove the front mudflaps, and possibly trim or adjust the plastic inner fender liner at minimum. You might need a BMC as well.
    I have BMC, front bumper cuts, modified (cut) fender liners, and the tire ripped one mudflap off when I turned and bottomed out the suspension on a trail run. I removed the mudflaps completely, and only rub slightly on occasion, probably on the firewall.
    A body lift will help some, but it won't help with the body mount.
    I don't think anyone is running 295's without a BMC. But, I'm sure someone will chime in if they are.
    What offset are your wheels?
    Mtbpsych, K-Paul, kmeeg and 1 other person like this.
  4. Jan 13, 2022 at 7:51 AM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    Yup, body lift ain’t gonna negate your need for a BMC
    K-Paul and Thatbassguy like this.
  5. Jan 13, 2022 at 7:56 AM
    Commited
    Commited New Member
    Oscar
    So Cal
    2019 Silver Metallic TRD ORP
    Tinted fronts, blacked out overlays.
    Don’t mean to threadjack but did you re-gear? Notice any significant loss in your MPG?
  6. Jan 13, 2022 at 8:10 AM
    @Thatbassguy as for the lift you got Bilstein6112 & 5160 right? 2.5in front + 2in rear? I forgot what uca you got. Spacer would drastically reduce the rear wheel articulation as the stock shock is not long enough right?
    2in spacer lift with stock uca would not clear 295s right? (even though op gets 1in body lift) And the offset of wheels would matter to clear the tires from rubbing right?
  7. Jan 13, 2022 at 8:24 AM
    No regear. It's definitely not fast! MPG depends heavily on speed. Have gotten almost 20 at 55-60 MPH, but as low as 11-12 at 80+ MPH. I usually average around 15.
    Yes, Bilstein. 2.3" front (according to the assembly instructions, never measured), and 1.5" rear (B12 coils). BDS UCA. They look similar to the Bilstein UCA's.
    I think stock VS aftermarket UCA is based more on lift height.
  8. Jan 13, 2022 at 9:33 AM
    Daytonaviolet
    Daytonaviolet TRD Bro
    Bay Area, CA
    Blizzard Pearl TRD Bro
    For my 295/70/17 RG’s and -38mm wheels I did bumper cuts, removed flaps, bmc and trimmed around the end caps and caster set to ~4.5+. I also trimmed some metal ears around the rocker end caps.
    i still get a slight rub somewhere during full reverse lock backing out of drive way sometimes. I’ll look at it again when it’s warmer. But daily driving has no rubbing.
    SunnyTRD, T-Runner and Thatbassguy like this.
