Lift point question
Discussion in '5th Gen 4Runners (2010-2024)' started by Michael95, May 14, 2024.
  1. May 14, 2024 at 8:18 AM
    Michael95
    Michael95 [OP] New Member
    I’m a newb with a 2016 SR5. I decided to change my own fluids. I’m uncertain but being led to believe there is a single central point where I can raise the front then place my jacks under the frame. Is this true? Is it the round bump I see on the skid plate? And, is the skid plate reinforced so I don’t have to remove it? (My thought is it doesn’t make sense to squeeze under to remove the plate so that you can then lift the 4R so you don’t have to squeeze under. But what do I know?). Thank you for your insights
  2. May 14, 2024 at 8:21 AM
    The skids are weak and you need to remove it for the change so don't use that. I lift from the frame rail with my floor jack when I need to but I have ramps for oil changes.
    djwantke and Michael95[OP] like this.
  3. May 14, 2024 at 8:25 AM
    Trees91
    Trees91 New Member
    Forrest
    South Dakota
    2023 MGM SR5p
    The skid plate has a brace in it so when you jack on that circle it's pushing up to a cross member.
    And I second what whippersnapper says. Ramps for oil changes make life easy.
  4. May 14, 2024 at 8:28 AM
    Michael95
    Thanks, I’m changing the diff fluids, every 90K whether it needs it or not:) , so I need level. I have 4 jack stands, but no ramps
  5. May 14, 2024 at 8:51 AM
    3X on the ramps. I use them for most work that doesn't require wheels off.
    If you're unsure of the central point, you can lift it up one side at a time by the frame. Just be careful to not go too high all at once.
    I have the RCI front skid, I use the center of that as my front lift point.
  6. May 14, 2024 at 8:54 AM
    Frame rails and rear axle will work.
    djwantke likes this.
  7. May 14, 2024 at 11:27 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
  8. May 14, 2024 at 11:49 AM
    steelevo
    Utah
    Welcome.
    There is a single lift point in the front, on the skid plate. From there, you’ll use jack stands on the frame rails. Look at the diagram in your owners manual.
    For the rear, the differential is the single jack point and you would place jack stands under the axles. Again, reference your owners manual for the exact lift and jack stand points.
    And most important, make sure that everything is stable and lifted safely before getting under the car.
  9. May 14, 2024 at 12:53 PM
  10. May 14, 2024 at 1:00 PM
    I’m just gonna leave this here.
    Sin4R, steelevo and djwantke like this.
  11. May 14, 2024 at 4:50 PM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    Except this diagram is not in all 5th gen manuals. Not sure if at some point they reinforced the center skid to accommodate this or just added it to the manuals.
  12. May 14, 2024 at 9:08 PM
    Gripster
    Gripster New Member
    2016 Trail Premium
    90k is way too long for differential fluid change.
    NE Runner and Rocko9999 like this.
