Lift or Level (For Beginners)
Discussion in '5th Gen 4Runners (2010-2024)' started by bone888, Mar 29, 2024.
  1. Mar 29, 2024 at 2:10 PM
    bone888
    bone888 [OP] New Member
    2022 4Runner SR5 White
    Hey yall! I have a 2022 SR5. I am very new to the scene of 4runner mods and builds. I have no intention of taking my 4runner off-road. The most "off-roading" it will probably do, is driving it to a camp site lol. All this to say, I don't know what to do with it when it comes to leveling or lifting it so it doesn't have that stock, forward leaning look.
    If I want it to look like the TRD Pro height, or something similar to it, what do I need and what should I do?
    Thanks in advance. And if theres an existing thread on this lmk!
  2. Mar 29, 2024 at 2:23 PM
    Welcome to the forum.
  3. Mar 29, 2024 at 2:26 PM
    HBJ32
    HBJ32 New Member
    I would get a .5 inch Cornfed spacer which would give you a 1 inch lift to match the TRD Pro. If not offroading this is the cheapest route to get the look you want and ride should remain the same as stock.
    djwantke and kevinRR like this.
  4. Mar 29, 2024 at 2:43 PM
    First off: Welcome aboard!
    Second: Thanks for admitting that you'll be a pavement princess. So few do. I'm a light off roader like yourself. The camp site roads I drive down could be navigated with a Honda Accord.
    Now....if that's what your main goal is, don't lift it or level it. You won't get the return on investment to lift it. Sure, it'll look cool, but can you afford to piss away the money on something you won't ever use? I don't know your financial situation, but I wouldn't burn money.
    Leveling isn't a great idea either, in my opinion. The "rake" is there for a reason. When/If you tow or haul something, the rake goes away. I'm not totally against it, but the look doesn't bother me. Try driving it for 2 - 5k miles before deciding to do a lift and/or leveling. Don't be quick to jump on the band wagon.
    Oh.........show us pics of your new ride!
    Ironguy, jgalt, Ripper238 and 3 others like this.
  5. Mar 29, 2024 at 3:20 PM
    Leave it be. Mine is stock and I off-road all the time.
    Welcome to the madness. ;)
    Ripper238 and djwantke like this.
  6. Mar 29, 2024 at 3:54 PM
    A1" lift in the front will still have rake, and looks infinitely better than stock.
    kevinRR likes this.
  7. Mar 29, 2024 at 6:35 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Get this done to it ^
    Welcome here dude @bone888
  8. Apr 1, 2024 at 6:00 AM
    cbrake
    cbrake New Member
    Cliff
    2019 Silver 4Runner
    Do you run AT tires? If so, which ones?
  9. Apr 1, 2024 at 6:17 AM
    Yes, Nitto Ridge Grappler’s, but that’s one of many many choices.
  10. Apr 1, 2024 at 6:37 AM
    jgalt
    jgalt New Member
    Looks are that important? Just know that all mods put that little bit of doubt/paranoia in your head. That squeak/rattle/knock makes you wonder if it's something about the mod or just a stock issue. If you have a problem, stock is easier to deal w/. Custom can be a life style lol.
  11. Apr 1, 2024 at 7:45 AM
    Ironguy New Member
    Drive for awhile then reevaluate.
    SlvrSlug and Slopemaster like this.
