Lift kit recommendations
Discussion in '2nd Gen 4Runners (1990-1995)' started by Maggot666, Oct 9, 2022.
  1. Oct 9, 2022 at 3:53 PM
    Maggot666
    Maggot666 [OP] New Member
    Steven
    1995 4runner 4x4 sr5
    stock
    New from South Jersey. Just got my 1995 4runner looking to lift and put bigger tires on it. Nothing crazy 33 or 35s. Looking for help and recommendations on where to start and how much lift I should do to fit bigger tires.. Thanks
  2. Oct 10, 2022 at 1:39 AM
    Welcome from Wisconsin! One of the best things you can do while on the forum is go to the upper righthand corner to the 'search' box. Type in what you're looking for and with the lift kit search I'm sure you'll be flooded with ideas! This is a fairly common topic around here. Good luck.
    canadian.bacon likes this.
  3. Oct 10, 2022 at 4:37 AM
    welcome
  4. Oct 10, 2022 at 6:11 AM
    Ironguy New Member
    Welcome!
  5. Oct 14, 2022 at 11:04 PM
    1ino
    1ino New Member
    Lino
    1994 Gold 4Runner
    removed running boards
    I lifted a bronco I use to have, only because I had to after installing different rims and tires, Now that I have a 94 4Runner, and knowing how much a lift and bigger tires will make it doggier than it already is, I am not lifting mine and don't recommend lifting
  6. Oct 15, 2022 at 10:29 AM
    trlhiker
    trlhiker Lazy Bum
    1992 4Runner SR5 V6 4X4
    I agree, don't lift but you do need to get rid of the rear squat. Replace the springs in the rear with some aftermarket ones and then put some 32's on it.
    Maggot666[OP] likes this.
  7. Oct 15, 2022 at 2:17 PM
    Maggot666
    Steven
    stock
    Trlhiker. Thanks for the input. Just really want it to look better but didn't know wh we e to start. Thanks so much
  8. Oct 15, 2022 at 3:56 PM
    1ino
    1ino New Member
    Lino
    1994 Gold 4Runner
    Sounds like you are not happy with its looks, a lift might make you dislike something else about it, from what I see in the picture, looks like the rear is lower than the front, I would try to get that leveled out if anything unless that's just the way the picture came out because its parked on sloped driveway.
  9. Oct 19, 2022 at 12:08 PM
    Alaskaflyer
    Alaskaflyer New Member
    1995 Toyota 4Runner SR%
    There are limited options, depending on how much lift your are looking for. A simple lift would be ball joint spacers and new rear coils (with differential drop) for around $300. If you are going to run bigger tires I would consider re-gearing.
  10. Oct 23, 2022 at 5:43 PM
    atgparker
    atgparker Cal Poly, ETME 1988
    Andrew
    Mission Viejo, CA
    1991 White 4Runner 3.0 L
