Lift kit help?
Discussion in '4th Gen 4Runners (2003-2009)' started by adamedwards271, Dec 1, 2019.
  1. Dec 1, 2019 at 6:29 PM
    adamedwards271
    adamedwards271 [OP] New Member
    Hi, I’m have a 2WD 2008 4Runner Sport with the urban package and I was wondering what lift kits to get. I’ve heard that with some packages and such you can’t get certain ones and I would honestly just like a little help and guidance with them! Thanks in advance!
  2. Dec 1, 2019 at 6:59 PM
    john8899
    john8899 New Member
    2019 Trd OR
    How do you plan on using it? Any off-roading?
  3. Dec 1, 2019 at 7:01 PM
    adamedwards271
    Yes, the lift kit will be for looks and off-roading, like some mud holes and trail going but I’d also like it to be a comfortable-ish ride for daily use too.
  4. Dec 1, 2019 at 7:04 PM
    john8899
    john8899 New Member
    2019 Trd OR
    Bilstein 5100’s and some coils is a pretty good entry level lift.
    I’d shoot a message to Marie, she is the lift kit wiz. And can get you set up at a good price. @HeadStrong Off-Road
    k1ng_Snoopy and SlvrSlug like this.
  5. Dec 7, 2019 at 5:54 PM
    Mohoman
    Mohoman New Member
    Sean
    99 Limited
    Queen of Battle
    Might consider getting a cheap used set off a Tacoma OP. It nets a mild lift and the ride can at times be a little aloofy but for the price. I purchased a set for $150 and then purchased the rear 9.8108G 3/4 eye bushing and its a direct swap! Cheers
    Edited: I believe the Tacoma uses Bilstein 4600.
  6. Dec 27, 2019 at 12:32 AM
    mrseth
    mrseth New Member
    Seth
    2004 Limited v8
    3" Rancho, 2.5" Delrin BL, 1.5" Supreme Spacer Lift, 35" Cooper MTP, Chopped Fenders, Racing buckets, 1.5" Spidertrax
    I'd have to recommend the Bilstein 5100 route utilizing your stock coils. Great ride, adjustable height (which in will turn into preload settings if you get lift coils), and pretty affordable. I run Pro Comp ES9000's for my rear with Pro Comp 3" lift coils in the rear which rides just right with my tire carrier and accessories.
    k1ng_Snoopy likes this.
