Lift gate chime alarm
Discussion in '5th Gen 4Runners (2010-2024)' started by DDD3, Nov 18, 2022.
  1. Nov 18, 2022 at 7:32 AM
    DDD3
    DDD3 [OP] New Member
    Don
    2014 4 Runner
    From time to time I need to drive short distances with my 2014 4runner lift gate partially open. Is there a way to disable the chime alarm either by removing a fuse or doing something that makes the electronics think the lift gate is closed. Appreciate any suggestions that can be offered.
  2. Nov 18, 2022 at 7:49 AM
    08TXRunner
    08TXRunner New Member
    '20 SR5P
    I can say that Carista does not have that option in case you are wondering.
  3. Nov 18, 2022 at 12:28 PM
    AuSeeker
    AuSeeker Old As Dirt
    Skip
    South Carolina
    2004 Limited
    Not sure what type or where it is on a 5th Gen but there either a push/plunger switch or a contact pad that tells the vehicle the hatch is closed, if it's a plunger switch you can either tape it pushed in or rig up something to hold it in, for a contact pad you would have to rig a jumper to connect the contact points.
  4. Nov 18, 2022 at 3:03 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    You can take a screwdriver and push the hatch door latch mechanism closed. Just make sure you open it again before attempting to close the hatch, otherwise you’ll damage it. Maybe put a big strip of duct tape on the hatch door to remind yourself. :eek:
    grizzlypath likes this.
  5. Nov 17, 2023 at 12:50 AM
    2023TRD
    2023TRD New Member
    2023 Nautical Blue TRD
    The idea I had was to use a small carabiner to push in the latch. (2 clicks) leave the carabiner in the latch and use it to tie down the hatch door.
    Harringbr99 and raimieb like this.
  6. Nov 17, 2023 at 11:36 AM
    Oakboro, N.C
    That too would also work. Comes down to what best suites your needs, for OP.
