Lift first? Tires First?
Discussion in '5th Gen 4Runners (2010-2024)' started by dmScott15, Mar 4, 2022.
  1. Mar 4, 2022 at 7:30 PM
    dmScott15
    dmScott15 [OP] New Member
    Danielle
    San Diego County
    2017 Magnetic Gray TRD Off Road Premium
    We are starting the process of looking for new tires and looking in to lifts. We have a 2017 TRD ORP. We do want to do a small lift, but we also need will need new tires soon. We’d like 275/285s AT (we’ll be moving from Ca to IN so snow rated)that won’t break the bank. Seems like Wildpeak AT is what we’re leaning towards. But should we do the lift first? Would 275s rub without a lift if we don’t trim the mudflaps or modify the body? We’re pretty new to all this…HELP!!!
  2. Mar 4, 2022 at 7:46 PM
    Mtbpsych
    Mtbpsych New Member
    Lots of threads on this, 275’s shouldn’t be an issue. With 285’s you may rub, depends how good of an alignment you get and then do some minor wheel well work.
    Toy4X4 likes this.
  3. Mar 5, 2022 at 1:34 AM
    suaveflooder
    suaveflooder New Member
    275’s are a “maybe” when it comes to rubbing. I’ve heard some people have no issues, some people rub. Even if you rub, it’s a simple mod to push the fender liner forward. I stayed with the 265’s because of weight. I don’t off-road.
    Toy4X4, TXKK626 and dmScott15[OP] like this.
  4. Mar 5, 2022 at 5:08 AM
    GenoBluzGtr
    GenoBluzGtr New Member
    Geno
    Maryland
    '22 TRD Pro - Black
  5. Mar 5, 2022 at 5:47 AM
    RLHOK
    RLHOK Keeper of the smoke and all things BBQ
    Rich
    Oklahoma
    2022 4Runner TRD Off Road
    2022 TRD off Road 4Runner, rolling stock baby.
    I did tires first. Stayed with the 265s in a falken wildpeak.
    I have been looking at lifts, the more I think I will hold off, and just do a spacer level for the front. Easier on the wallet and I can start saving for a lift if I decide to go that route.
    Slopemaster, K-Paul, Toy4X4 and 2 others like this.
  6. Mar 5, 2022 at 5:52 AM
    What wheels do you currently have on there?
    Do you know the offset?
  7. Mar 5, 2022 at 6:19 AM
    nightflyer
    nightflyer New Member
    Jason
    Ft Worth, TX
    2020 Venture
    I’m not sure what your mission is but I bought my 4Runner to go camping in the backcountry. I went with all-terrain tires, BFG KO2’s in stock size, first with stock suspension. That’s a very capable combination for what I do. I recently did get a lift with 285 size tires and that’s a great combination but you will take a hit on gas mileage. B11178F5-2E95-4033-AA55-152E03B15D84.jpg F51F3827-2726-4248-A8BF-D60BFD06C55A.jpg
    hossler1788, Mtbpsych, Toy4X4 and 2 others like this.
  8. Mar 5, 2022 at 11:23 AM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    You'll take less of a mpg hit with sl rated or 4 ply all terrains just cause theu are a bit lighter, mate them with a set of wheels that weigh less then 28lbs(each) and you'll be golden, with my 285 set up I'm averaging 17-18 mpg and my foots on the gas pretty much all times
  9. Mar 5, 2022 at 5:34 PM
    dmScott15
    Danielle
    San Diego County
    Currently have 265/70/17 w/nankang crosssport tires. Tires we bought it with. We’ve got the black TRD pro rims on it which will stay. We mostly want to do a lift bc we like the look and for some off roading.
    Toy4X4 likes this.
  10. Mar 5, 2022 at 5:37 PM
    dmScott15
    Danielle
    San Diego County
    Did you need to do any body chop to make the 285 for without rubbing? Or just the lift.
  11. Mar 6, 2022 at 2:39 AM
    Matt83
    Matt83 New Member
    Northeast
    Great looking truck.
  12. Mar 6, 2022 at 3:36 AM
    nightflyer
    Jason
    Ft Worth, TX
    2020 Venture
    I have the Toytec Aluma 2.5 with the SPC upper control arms. The only trimming we did was about 1/4 inch of plastic in the front of the tire and we removed the front mud flaps. I did take it off road on our camping trip to the Big Bend and there was no rubbing. I’m no expert, but my understanding is that the SPC UCA’s allow them to change the castor enough so that it doesn’t rub.
  13. Mar 6, 2022 at 8:36 AM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Right now I'm running 285s on stock sr5 susp. And yes it rubs, I trim and moved the inner fender around so now its not rubbing on the plastics BUT it does rub the body mount on full lock, I knew this would happen with my -12 offset. But my 5100 and jba uca are ordered, which might fix the rub if not ill chop it
    suaveflooder likes this.
  14. Mar 6, 2022 at 9:20 AM
    With Pro wheels and your particular truck, you will probably rub with 275's and 285's. Your lift doesn't really factor into this because you would still rub with the Pro wheel offset and a bigger tire whether you are lifted or not. Rubbing mostly comes from scrub radius on our trucks.
    To fix this, you would need to do the fender liner mod (super easy) and have the correct alignment (caster around 3.5 or higher).
    If you lift your vehicle north of 1.75", then you will not be able to get your stock UCA's above 3.5 degrees of caster, in which case you could start rubbing to the rear of your wheel well on the mudflaps or body mount. That rub can be fixed as well. Not as easy as the fender liner mod, but not too bad either. Body mount chop is probably best left to a professional unless you know how to weld.
    Aftermarket UCAs allow you to increase your caster with higher lifts to potentially avoid the body mount chop and mudflap rub.
    rangers1976 likes this.
  15. Mar 6, 2022 at 11:10 AM
    4runnerwanted
    4runnerwanted New Member
    I'd go with lift and tires at the same time. Especially if you want to go bigger tires. Little less labor when getting all the work done (if you're shopping it out).
    polyguy79 likes this.
  16. Mar 7, 2022 at 6:43 AM
    TRDTitus19
    TRDTitus19 New Member
    PA
    ‘19 TRD Pro
    2019 TRD Pro: Westcott Designs PRO Lift Kit / SCS Ray10s Matte Black -10mm / 285s Toyo O/C AT3 / Spidertrax 1.25” Spacer/ K&N CAI / Diode Dynamics Tail-As-Turn Kit / Rigid Industries Flood Ditch Lights / CaliRaised Low Profile Ditch Lights Mount / 15% Tint / Seven Sparta Amber Grill Lights / AuxBeam LED bulbs / Tactilian American Flag Decals / Shackle Receiver ⛰
    Lift first… Westcott Designs is highly recommended!
  17. Mar 18, 2022 at 8:23 AM
    Sandman317
    Sandman317 New Member
    2022 AG ORP
    How do you like those 2.5s? Im considering them for mine but just not a lot out there on them. Would love to hear your feedback on them.
  18. Mar 19, 2022 at 6:30 PM
    donnermel
    donnermel New Member
    dita.yota
    Truckee/Tahoe
    ‘16 Trail Premium Super White w/ KDSS
    Dobinsons lift and UCA, RCI sliders and front engine skid, H9 bulb swap, Sprint Booster, KnN air filter, Canvasback covers, Raingler cargo net, AVS Window Shade deflectors, Heritage Grill with raptor lights Summer Wheels: Ryder RR03 matte gunmetal with Falken Wildpeaks 285/75/17 Winter Wheels: 18” KD Wheels with Blizzaks Rack is OEM - but changed to black with LFD crossbars Diode Dynamics Ss3 fogs
    How about lift, wheels and tires all at once!! Finally did it!! Rides so smooth now. Can’t wait to take it out in the dirt.
  19. Mar 19, 2022 at 8:38 PM
    Sandman317
    2022 AG ORP
    Sitting nice, what Dobinson combo did you go with?
  20. Mar 19, 2022 at 9:00 PM
    donnermel
    dita.yota
    Truckee/Tahoe
    Thank u!! I went with the basic twin tube lift- about 2.5” front, 2” rear. Did the Dobinsons UCAs too.
    C59-302
    GS59-700
    C59-325
    GS59-705
    Sandman317[QUOTED] likes this.
  21. May 14, 2022 at 2:26 PM
    blackcloud08
    blackcloud08 They're Watching Us....
    How do you like the Aluma 2.5 kit?
  22. May 16, 2022 at 2:42 AM
    Jrunr
    Jrunr 2021 TRD Pro
    Jason
    2021 Magnetic Grey Metallic TRD Pro
    I have a 21 Pro and want to swap out my 265 Ridgegrapplers for 285 Ridgegrapplers and I am debating between the Eibach Springs and the Westcott lift (leaning more towards the Eibach…). Any thoughts on this?
    YetiMtnBkr likes this.
  23. May 16, 2022 at 5:17 AM
    YetiMtnBkr
    YetiMtnBkr New Member
    Frederick, MD
    2021 LR Pro
    None
    I am in the same boat! I'm not in a hurry to have this done, but am leaning towards the Eibach Springs as the best option for a modest lift.
  24. May 16, 2022 at 8:26 PM
    For more money, you can get spacers from Westcott.
    For less money, you can get coil springs from Eibach.
  25. May 16, 2022 at 9:53 PM
    Altitude4x4
    Altitude4x4 New Member
    2019 Voodoo Blue TRD Pro
    Be aware that you can't add any extra weight with those options. Eibach is just a taller spring but oem spring rate and westcott is a glorified spacer.
