Lift concern synopsis
Discussion in '5th Gen 4Runners (2010-2024)' started by CORunner, Mar 23, 2021.
  1. Mar 23, 2021 at 10:38 PM
    CORunner
    CORunner [OP] New Member
    All Ive been scouring thru the forum as I begin my build. Is it accurate to say that a three inch lift on the 5th Gen platform is really the point of increased concerns and need for diff drop, extended ucas and possibly rear LCAs? Is there any real correlation to the needle bearing issues and lift height or is this seen regardless of lift? Thanks
  2. Mar 23, 2021 at 10:57 PM
    Yes, except for the diff drop and rear control arms (never saw those needed)
    Mostly lifted, but stock vehicles have experienced this also.
    Thatbassguy and MeefZah like this.
  3. Mar 24, 2021 at 11:51 AM
    koukimonster
    koukimonster DYNO4
    Appalachia
    Midnight Venture
    Extended UCAs? Aftermarket, adjustable UCA's are typically necessary somewhere in the 2-3" lift range.. "necessary" depends on who you ask. I believe most would say necessary at 3", some say necessary at 2", others say definitely not. Some claim not necessary at 2.5", but most with the funds will do it anyway and with good results.
  4. Mar 24, 2021 at 4:38 PM
    Agent_Outside
    Built 2011 T4R Limited
    -is it accurate to say that a three inch lift on the 5th Gen platform is really the point of increased concerns - yes
    -need for diff drop - no
    -extended ucas - no
    -rear LCAs - no
    -is there any real correlation to the needle bearing issues - yes
  5. Mar 24, 2021 at 4:58 PM
    UCA's will probably be necessary at 3".
    My needle bearing was acting up within a few weeks of purchasing new (with stock suspension). I had it warrantied and now I'm lifted 2.3" with no problem (yet).
    Toy4X4 likes this.
