License plate install, help!
Discussion in 'General 4Runner Talk' started by Tyotor, May 14, 2024.
  1. May 14, 2024 at 4:36 AM
    Tyotor
    Tyotor [OP] New Member
    Don
    2016 SR5 Premium
    Sorry to put this on the 4Runners forum, but you guys are the smartest and most resourceful vehicle owners on the planet! I bought my wife a Highlander. The previous owner installed those tamper-resistant license plate bolts. I asked my mechanic to remove them since I didn't have the special allen wrench. I disposed of them and decided to purchase some regular stainless steel M6 license plate bolts. The problem is, they will only thread in about three thread lengths and then stop.
    Any thoughts on why that may be? Thanks for your time and wisdom!
  2. May 14, 2024 at 6:35 AM
    TrailSpecial22 New Member
    PA
    You will need to find out if you should be using a coarse or fine thread bolt. If you have the correct threads, you may have to run a tap through them to clean up the threads before tightening down the bolt. Good luck!
    djwantke and Spare Parts like this.
  3. May 14, 2024 at 7:38 AM
    Yobruhitsme
    Yobruhitsme New Member
    Denver
    Ineos Grenadier
    Front or back?!
  4. May 14, 2024 at 10:08 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Hey,
    TrailSpecial has great wisdom indeed.
    Dang too bad you disposed of the previous fasteners. Without knowing the depth or thread pitch, the key is to stop turning when the screw tells you I’m not turning any further! Once you strip those suckers you’ll be faced with the horrifying situation I put myself in on the back of my 4R;
    The Philips head stripped on my cheap plate cover screws when I replaced the cover…Screw Extractor tool failed, and I had to drillbit the screw heads off, pre drill a hole into the screw shaft, and sunk self tappers in as my new plate screws HAHA. Savage.
    But now my wife and I get honked at all the time:
  5. May 14, 2024 at 3:14 PM
    PA
    And dont forget a dab on antiseize on the bolt. You’ll thank yourself later.
    djwantke likes this.
  6. May 14, 2024 at 3:30 PM
    Just a little dab of anti seize :laugh:
  7. May 14, 2024 at 4:06 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    That's what I look like after every time I use it.
  8. May 14, 2024 at 4:10 PM
    PA
    too funny!!
    djwantke[QUOTED] likes this.
  9. May 14, 2024 at 5:41 PM
    Tyotor
    Don
    2016 SR5 Premium
    Thanks for all the replies. I ran an M6 tap through and it worked! It was the back license plate. You guys are the best!
    djwantke and TrailSpecial22 like this.
