Leveled out with bilstein 6112
Discussion in '5th Gen 4Runners (2010-2024)' started by Fishnchix, May 7, 2023.
  1. May 7, 2023 at 5:42 PM
    Fishnchix
    Fishnchix [OP] New Member
    2023 4runner offroad
    So figured I'd share. Was stressful finding the right rims and tire size and what setting to put my new shocks at . Hope this helps someone down the road if they go with bilstein.
    Anyhow . Leveled the front end with bilstein 6112 . The heavy duty spring version . Ended up putting the lock rings at the lowest setting and is pretty close to level. And this rig has kdss. 1/8 inch high in the front but hard to tell. With a new front bumper should be exactly level . Went with black rhino wheels primm with zero offset at up to 275/70/17 bfg ko2s..
    Cheers
    java, Mass4runner, Dabigono and 5 others like this.
  2. May 7, 2023 at 5:42 PM
    Fishnchix
    Oh and zero rubbing and cutting involved
    weezol and SlvrSlug like this.
  3. May 7, 2023 at 6:39 PM
    HuskyMike
    HuskyMike New Member
    Looks good. Assume you left the rears alone?
    Fishnchix[OP] likes this.
  4. May 7, 2023 at 7:25 PM
    steelevo
    Utah
    Welcome. Looks good!
  5. May 7, 2023 at 7:34 PM
    Fishnchix
    Yea was gunna lift the rear a bit that way I could lift the front more to fit 285s but with the kdss it was gunna be a little more of pain so left the rear stock. Happy with it though. Tires filled out the wheel wells better than I thought
  6. May 7, 2023 at 7:50 PM
    afret
    North Idaho
    Looks great! But seems like your frame now has a negative/reverse rake.
    2016Pro likes this.
  7. May 7, 2023 at 8:12 PM
    Fishnchix
    Thanks. It's very close to level . Hard to measure but with just using a tape it's about 1/8 inch higher in front. Hopefully the new heavier bumper will take care of it . If not I'll have to mess with the rear
  8. May 7, 2023 at 8:27 PM
    Looks good! A slight reverse rake isn't the end of the world, but you might want to adjust your headlights. Also, if you tow or haul often, you could end up with a Carolina squat look. :D
    Lift doesn't really clear tires. It just hides the rubbing until you flex the suspension.
    There are plenty of lifted 4Runners with KDSS here, including mine.
  9. May 7, 2023 at 8:45 PM
    Fishnchix
    Thanks . Haha yea not towing with this little gutless v6 .. I'll leave that to my tundra ..
    And explain how a lift doesn't help clear tires though ?? definitely helps. Backspacing is huge but surely a little height helps from what I can tell???
  10. May 7, 2023 at 8:56 PM
    Mine tows just fine. Don't exceed the weight limit, keep it in S4 and keep it under 65. Of course it doesn't pull like a V8, but it's just fine for lighter trailers.
    Again, lift doesn't help. It just hides the rubbing.
    Rather than beating a dead horse, I'll let this guy explain. Fast forward to ~8:00, or watch the whole video for some great information.
    Btw, backspacing is a less important consideration than offset, as offset is ultimately what determines where the tire will sit in relation to the hub.
    https://youtu.be/LAYGdcKSA3o
  11. May 7, 2023 at 10:18 PM
    Tomato, tomahto. You can't change one without affecting the other. 8" wheel, change the backspacing, the offset follows suit.
    Jareds Toyota likes this.
  12. May 8, 2023 at 2:38 AM
    You can if you're comparing wheels of different width. That's why it's better to go by offset, IMO.
  13. May 8, 2024 at 12:03 PM
    SLVRNR
    SLVRNR New Member
    Greg
    SR5 Silver 4Runner
    n/a
    So you didn't have to use any aftermarket uca's??
    Also, if you raise the rear, can you get away with just a block, or do you need the springs as well??
    New to the 4runner suspension, but thanks in advance.
    Your runner looks good!!!
  14. May 8, 2024 at 12:47 PM
    You may or may not get a response...OP was May of 2023, hasn't been seen since.
    No idea what the OP did about the rear, but a 1/2" or 1" spacer would have done the trick.
    2016Pro likes this.
  15. May 8, 2024 at 3:08 PM
    SLVRNR
    SLVRNR New Member
    Greg
    SR5 Silver 4Runner
    n/a
    Aight. Thanks again. Much appreciated.
  16. May 20, 2024 at 8:07 AM
    java
    java fauxrunner
    2023 ORP ice cap
    Sweet did you get preassembled coilovers? Thanks for sharing!
  17. May 20, 2024 at 10:37 AM
    See post #14.
    java[QUOTED] likes this.
