Level?
Discussion in '5th Gen 4Runners (2010-2024)' started by afret, Feb 11, 2022.
  1. Feb 11, 2022 at 2:33 PM
    afret
    afret [OP] 2022 ORP, KDSS, Toyo AT3
    North Idaho
    I've read that on a stock 4R, the front is usually around 2" lower than the rear but is that accurate? This number seems to come from measuring to the top of the wheel openings but are the front and rear wheel openings cut the same? Is the actual difference closer to 1"?
  2. Feb 11, 2022 at 2:48 PM
    MazMan
    MazMan New Member
    I’ve always heard 1”, and that’s what mine measures.
    a47chuck likes this.
  3. Feb 11, 2022 at 6:20 PM
    afret
    North Idaho
    I'm kinda having second thoughts about setting the front Eibach shocks at the second groove which should raise it about 0.8". If it's pretty level there, any significant weight in the 4R will probably cause a negative rake. Might be best to leave it at he lowest setting with no front lift since I don't want to raise the rear.
  4. Feb 11, 2022 at 6:26 PM
    Commited
    Commited New Member
    Oscar
    So Cal
    2019 Silver Metallic TRD ORP
    Tinted fronts, blacked out overlays.
    i was told by Eibach that the first setting allows for rake in the front and the second setting levels out the 4runner.
  5. Feb 11, 2022 at 7:31 PM
    afret
    North Idaho
  6. Feb 11, 2022 at 8:46 PM
    Commited
    Commited New Member
    Oscar
    So Cal
