Level or Sag?
Discussion in '5th Gen 4Runners (2010-2024)' started by farillustrator89, Jul 27, 2024.
  1. Jul 27, 2024 at 12:03 PM
    farillustrator89
    farillustrator89 [OP] New Member
    Hi everyone, i recently installed the wescott designs pre load collar kit (3" front 1.5" rear) on my 5th gen 2023 4runner sr5 premium. When i measure, everything is level (+=.1 inches) 38.2ish inches from ground to top of fender all around, but why does it look like the back is sitting lower than the front or is that just me? Maybe i am just used to my car having a rake not being leveled? Curious to know what you guys think. Thanks!
  2. Jul 27, 2024 at 12:13 PM
    First off, it does look like your 4Runner is squatting to pee. Your ass is sagging in the back. Fix that.
    Second off, learn to rotate your phone before taking a picture. That way we don't look at a picture that is 2/3rd's black blocks.
  3. Jul 27, 2024 at 1:10 PM
    RLTW
    RLTW New Member
    Phoenix, Arizona
    '22 AG ORP
    Contact Jeff or Brian @ WD and they will assist you with any questions you may have.
    farillustrator89[OP] likes this.
  4. Jul 27, 2024 at 3:21 PM
    nova
    nova New Member
    mike
    Prescott Valley - Arizona
    slightly modified LE
    djwantke likes this.
  5. Jul 27, 2024 at 3:32 PM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    Once you get it sorted, make sure to ADJUST YOUR HEADLIGHTS!
    2Toys, djwantke, alittleoff and 2 others like this.
  6. Jul 27, 2024 at 4:59 PM
    dosomeplowin
    dosomeplowin New Member
    '24 ORP
    The frame and body lines of the 4Runner make it very squatty if the distance from ground to top of the fenders matches front/rear.
  7. Aug 10, 2024 at 6:18 PM
    farillustrator89
    Thank you all for ur inputs. I stripped the wescott kit off and got bilstein 6112 front at 2” and 5100 in the rear at 1.5. They drive 10x better than the wescott kit which drove way worse than stock. My mpg also improved bc i was not nose up lol
    2Toys, Fortuner and djwantke like this.
  8. Aug 10, 2024 at 6:52 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Yeah I was gunna say, your not actually level, there’s a natural rake - the fenders are at different heights so even when your level the gap from tire to fender in the rear is larger. If you towed, you’d be nose to the sky :)
    Bilstein ftw lol
  9. Aug 10, 2024 at 6:53 PM
    Wise man
  10. Aug 10, 2024 at 6:54 PM
    Classic Borracho Loco lol
    I’m actually dying to get my front end higher after it had settled now. Ima click the 5100’s up from 0” to the first spring groove setting
  11. Aug 13, 2024 at 8:05 AM
    daneo
    daneo New Member
    Dane
    As mentioned earlier, the fenders in the rear go up higher than the fenders in the front. Measuring the front and rear of the running boards or the frame behind the running boards will help on determine if the truck is level or raking one way or the other. All the photos on westcott's website are rear-raked too :bananadance:
  12. Aug 14, 2024 at 11:40 AM
    If only it were as easy as 'clicking'...
    djwantke[QUOTED] and LCJ77 like this.
  13. Aug 14, 2024 at 11:46 AM
    94hokie
    94hokie New Member
    23 TRD ORP Lunar Rock
    I think your setup as it is now looks great, I wouldn't change it.
  14. Aug 14, 2024 at 12:05 PM
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    2023 TRD Pro Ice Cap
    Just put a 6" torpedo or a 3' level in the center of the steps.
    daneo likes this.
  15. Aug 14, 2024 at 3:54 PM
    Right!? I gotta take a little YouTube university before I attempt lol
  16. Aug 14, 2024 at 6:44 PM
    Because it is squatting
    First you need to put a level on your running boards or rocker panel
    Then put a level on your window trim and rear window
    You will notice the window trim is slightly raked upward in relation to the rocker and running boards.
    When you lift the vehicle, you need about 7/8" higher in the rear to "look" level on the rocker and running boards. By having this extra height gap in the rear fender, you would "think" it has some rake, but this is what is required to keep it level.
    Also when its "level" meaning the rocker and running board is level, the bottom window trim will have an upward rake towards the rear.
    If you want the VEHICLE to be level, you need about +7/8" higher in the rear than the front
    If you want the lower window trim to be level, the rear will be squatted slightly which will give a downward rake to the running board and rocker panels.
    Is your front adjustable or just a puck spacer? I would venture to say you need to get a slightly thinner spacer to try to drop the front end about 3/4".
