LED lights
Discussion in '4th Gen 4Runners (2003-2009)' started by Micorama, Feb 21, 2024.
  1. Feb 21, 2024 at 7:52 PM
    Micorama
    Micorama [OP] New Member
    2005 4Runner
    Has anyone tried using LED’s. I changed just the front turn signals with LED’s. I noticed they are not bright and they blink quickly like it does when you have a burned out bulb. Does this mean I have to change all the turn signals with LED’s? Thanks!!!
  2. Feb 21, 2024 at 9:13 PM
    You need LEDs with built-in in resistors. Something like this one -
    https://amzn.to/49IcPq1
    Make sure you buy the correct bulb for correct year/make/model & location front / rear. No I'm not a seller. Just an average customer.
    Also I don't have LED turn signals. It's not my comfort zone. I play with led headlights, reverse lights, interior lights but not turn signals.
    Micorama[QUOTED][OP] likes this.
  3. Feb 22, 2024 at 5:31 AM
    bronzestar1
    bronzestar1 New Member
    2023 Limited magnetic gray with redwood interior
    275/55-20s, Airaid CAI, Summit muffler, oil catch can
    Had the same issue when I swapped to LED turn signals on my '23 Limited. Replaced them with ones that had built-in resistors, and the fast-blinking went away, they work like normal now.
    Micorama[OP] likes this.
  4. Feb 22, 2024 at 5:59 AM
    I have this exact(Ithink?) turn signal LED bulb for my 2023 4Runner. I have no hyper flashing and the install was rather easy. All the other LED's that I tried, hyper flashed and when I called their customer support, they told me to install a resistor (which cost extra money).
    This is how bright mine are (they are also switch backs):
  5. Feb 22, 2024 at 7:24 AM
    J.A.
    J.A. New Member
    NY
    2007 4Runner Sport 4WD V-8
    www.top4runners.com
