LED Headlights
Discussion in '5th Gen 4Runners (2010-2024)' started by SR5TRDWANAB, Nov 21, 2020.
  1. Nov 21, 2020 at 7:47 PM
    SR5TRDWANAB
    SR5TRDWANAB [OP] New Member
    2014 Black 4Runner SR5S
    I want to put all LEDs in my stock headlights. Want I want the most is brighter amber lights when my DLR are on. Anyone have a suggestion for a LED replacement that aren’t switchbacks.
  2. Nov 21, 2020 at 7:56 PM
    Gamma Ray
    2020 SR5 Barcelona Red
    Maybe save yourself some money and try these: https://www.amazon.com/gp/product/B00U1OIESK/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
    If you don't like them and must go LED in your headlights, then get the Lasfit 4Runner specific LED headlights. I wouldn't bother putting generic LEDs in there. I have them, and I like them, but I think I would have rather tried the above ones first.
  3. Nov 21, 2020 at 9:05 PM
    Abanero
    Abanero New Member
    2015 Inferno Orange 4Runner TRD Pro
    LASFIT has every light replacement you can imagine for the RUNNER. I’ve installed switchback fog, side marker, switchback blinkers in the front, rear blinkers, reverse lights, and all interior. I couldn’t be happier w/ the product thus far.
  4. Nov 21, 2020 at 9:52 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    @SR5TRDWANAB Are you specifically talking about the amber lights located outboard of the headlights that flash when your turn signal is used? I think some guys are thinking you mean LED headlight bulbs.
  5. Nov 21, 2020 at 10:13 PM
    Pyroslinger
    Pyroslinger 1995 Hi-Lux Surf 3.0 3VZE Factory 250,000
    Pyroslinger
    Montana
    1995 Hi-Lux Surf SR-5 3.0 3VZE / Bought at 29,000 - Present 250,000/ Rusted Body, Excellent Otherwise
    Factory/ 2" Ol Man Emu Rear Springs/ Skyjacker Shocks/ Cat- Back Exaust/ K&N Air Filter/ Denso Iridium Plugs/Neoprene Vacume Lines/Sony CD Head Unit+Focal Factory Fit Speakers
    I agree with Gamma Ray and Abanero, I tried several types of LED Headlamps. Lasfit LA Plus 9004 HB1 https://www.lasfit.com/products/lcp...5~zq_standard-trims~dz_high-beam-and-low-beam
    Fit my 1995 4Runner headlamps for direct replacement perfectly. However, they must be installed correctly and positioned with the Offset LED chips at the bottom of the chip board when inserted. The chip board must inserted vertically with the LED at the bottom (thin narrow chip board positioned up and down not side to side). Then aim them at a wall, for perfect light pattern and true bright/dim beams. The only drawback I found was there will be no more HI/Low Beam indicator on your dashboard. These bulbs are super bright and intense white, so be sure and aim them very low as to not blind oncoming drivers. You will know when they are on Bright and if they are aimed too high. I love these headlamps!
