Led headlight and fogs
Discussion in '5th Gen 4Runners (2010-2024)' started by titan34, Dec 28, 2016.
  1. Dec 28, 2016 at 4:29 PM
    titan34
    titan34 [OP] New Member
    Hawaii
    Hi
    I have a 2016.4runner looking to upgrade my headlights and fogs to leds. Anyone has upgraded to leds? If so how do you like them? On the fog lights is the bulb size H16 or H11 Like the headlights on the 2016 t4r?
  2. Dec 28, 2016 at 5:38 PM
    Dark Knight
    Dark Knight Get off my lawn
    Led in the low beams are terrible. Go hid for them
  3. Dec 28, 2016 at 5:45 PM
    titan34
    Hawaii
    Thanks ...which hids are good?
  4. Dec 28, 2016 at 5:46 PM
    Dark Knight
    XenonDepot.com
    I went with the 4300k philips bulbs. Outstanding!
  5. Dec 28, 2016 at 5:51 PM
    titan34
    Hawaii
    sent pm
  6. Dec 28, 2016 at 7:08 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    I also have the Xenon Depot HID's in my lows. They're awesome. I went for the 5000K kit to match my Morimoto XB fog lights.
  7. Dec 28, 2016 at 7:40 PM
    titan34
    Hawaii
    Cool..Pm you
  8. Dec 28, 2016 at 7:47 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    Posted for others with the same question...
    I have a 2016. The Morimoto fogs are pretty easy to install, no need to remove the bumper, you can reach from underneath the vehicle. There are two tabs and two screws. Unscrew the screws and slide the fogs out of the tabs that hold it in. I can get some pictures for you but its pretty easy, took me about an hour.
    As far as the HID's they're pretty easy as well, the whole system is plug and play. The only thing you have to figure out is how to route the wiring, and how you want to run the wires to the ballasts and the bulbs. I drilled through the dust caps and sealed it with silicone.
  9. Dec 28, 2016 at 7:48 PM
    titan34
    Hawaii
    Thanks!...where did you order the morimoto fogs from?
  10. Dec 28, 2016 at 7:51 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    I bought mine from Amazon here... https://www.amazon.com/Morimoto-Type-LED-Projector-Light/dp/B00XA3C2FA I had a gift card so I got them for a pretty good price. I think the retrofit source might have them for cheaper however.
  11. Dec 28, 2016 at 7:53 PM
    titan34
    Hawaii
    Thank you..I will check them out
  12. Dec 28, 2016 at 10:15 PM
    titan34
    Hawaii
    Do you have to adjust the housing when you put these hid's in? Will it be ok how it is set?
  13. Dec 28, 2016 at 10:31 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    With painters tape mark a line on a garage door or wall with the center and cutoff of your current bulbs. Put the HID's in and and adjust them to match. You may not need adjusting, mine lined up the same before and after.
  14. Dec 28, 2016 at 10:35 PM
    titan34
    Hawaii
    Thank you
  15. Dec 29, 2016 at 9:17 AM
    titan34
    Hawaii
    Got pics of your xenondepot hid and morimoto fogs?
  16. Dec 29, 2016 at 10:21 AM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    This is the best I got right now, I can get some night pictures for you later.
    Vernsstar and Palerider like this.
  17. Dec 29, 2016 at 10:26 AM
    titan34
    Hawaii
    Pulled the trigger on the xenondepot hid extreme 5000k and morimoto fogs. I was looking at the morimoto hid as well...Thanks PVT pabalo!
  18. Dec 29, 2016 at 10:28 AM
    titan34
    Hawaii
    It looks really good! Nice trd pro.. lifted.
  19. Dec 29, 2016 at 10:30 AM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    Nice! You'll be happy with your purchase. Good call going with the Xenondepot HID's. I've heard problems with the Morimoto HID's so I didn't get them.
    Thanks man!
  20. Dec 29, 2016 at 10:35 AM
    titan34
    Hawaii
    I was opting for the xenondepot led fogs but you have the morimoto and it matches so I went with it
  21. Dec 29, 2016 at 10:37 AM
    titan34
    Hawaii
    Did you get the yellow protected film on your fogs as well?
  22. Dec 29, 2016 at 10:38 AM
    titan34
    Hawaii
    I'm hoping I can install the fogs without removing front bumper. I know your trd is lifted. I just leveled my front 1inch.
  23. Dec 29, 2016 at 10:45 AM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    Nope went with the standard clear.
    You won't have to remove the bumper, I didn't.
  24. Dec 29, 2016 at 12:46 PM
    titan34
    Hawaii
    Thats good to know.
    Did you have to reverse the polarity on the connection?
  25. Dec 29, 2016 at 12:59 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    Nope. Plugged right in normal the first time.
  26. Dec 29, 2016 at 6:18 PM
    titan34
    Hawaii
    Did you use #9 step drill bit as well to drill the dust cover?
    Is there a small gap from the fog light lens to the plastic? I heard they don't fit flush.
  27. Dec 29, 2016 at 7:26 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    This is the drill bit I used...
    https://www.amazon.com/dp/B000FZ2UOY/ref=cm_sw_r_cp_apa_BnDzybJCDTCZ3
    The Morimotos don't fit flush, there is a 1/4" gap but I'm pretty OCD about my vehicles and it doesn't bother me.
  28. Dec 29, 2016 at 7:42 PM
    titan34
    Hawaii
    Cool!.. Thanks.. I'm pretty OCD as well so if it does not bother you it will probably be fine with me too.
  29. Dec 30, 2016 at 12:19 PM
    titan34
    Hawaii
    I went to look up under the fenderwell to check out the fog lights..The driverside looks workable to remove but the passenger side fogs has this plastic cover looking thing which makes it diffcult to get to.. Did yours have that? I'm trying to figure out how to remove it.
  30. Dec 30, 2016 at 12:49 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    The plastic cover is held in by 3 tension clips. Just pull away from the front bumper and it'll come out.
