Lean Correction. How much is normal?
Discussion in '5th Gen 4Runners (2010-2024)' started by 1SilverRunner, Jan 15, 2025 at 5:38 AM.
  1. Jan 15, 2025 at 5:38 AM
    1SilverRunner
    1SilverRunner [OP] My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-675v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered. Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    For you non kdss 4Runners with a lift, how much driver side lean do you have?
    I recently measured the lift height at all 4 corners to see how much rake and lean I have.
    Noticed the front end leans .4" left. The rear leans .5" left. Funny thing is I already have a .4" lean correction spacer on the driver rear.
    I think I'll swap the .4" lean correction spacer for a 1" spacer.
    I know it's a small detail that I could ignore. But the spacers are pretty cheap and easy to add.
    The question is:
    How much lean did you have with your lift?
    and
    What lean correction do you have in place and how much correction did it actually do?
  2. Jan 15, 2025 at 6:56 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    I'm not sure if it's because I have an older 5th Gen (2011), but when I swapped out the XREAS for OME there was no noticeable lean anywhere. All 4 corners pretty much matched and lifted where expected.
  3. Jan 15, 2025 at 7:06 AM
    Try shifting gear (assuming you have gear back there) in your rear cargo area from the drivers side to the passenger side. Since the height difference is minimal, I bet shifting 50lbs from one side to the other will fix it.
  4. Jan 15, 2025 at 7:14 AM
    Stock SR5 and no noticeable lean.
  5. Jan 15, 2025 at 7:25 AM
    Based on my TRD Pro video (center on wheel to lower part of wheel well)
    Driver side Front - 53.5cm (21in)
    Passenger side Front - 53.5cm (21in)
    Driver side Rear - 56.5cm (22.25in)
    Passenger side Rear - 56.5cm (22.25in)
    Based on my Limited video - Ironman FCP lift (center on wheel to lower part of wheel well)
    Driver side Front - 56.5cm (22.25in)
    Passenger side Front - 56.5cm (22.25in)
    Driver side Rear - 59.0cm (23.25in)
    Passenger side Rear - 59.75cm (23.5in)
    Based on my TRD ORP video - OME Nitro lift (ground to lower part of wheel well with BFG KO2 285/70R17 tires)
    Driver side Front - 97cm
    Passenger side Front - 97cm
    Driver side Rear - 99.5cm
    Passenger side Rear - 101cm
  6. Jan 15, 2025 at 8:34 AM
    1SilverRunner
    Tejas
    The thing I'm concerned with is if I add a one inch lean correction spacer will I get one inch of lift on that side?
    I'm curious if the spring compressing more due to the spacer will also lift the vehicle slightly. If that's the case maybe I should do a 3/4" spacer in order to get 1" of lean correction.
    Unfortunately I cant find a ton of posts about hub to fender measurements before and after lean correction. So I decided to ask the gurus here.
  7. Jan 15, 2025 at 8:58 AM
    Kezin
    Kezin New Member I guess?
    ‘21 and ‘17 Limiteds
    I just installed a lift on my 2021 on Monday. I knew the vehicle already leaned to the driver’s side a bit so adjusted the front coil seat height up 1/4” and that seems to have worked for me. It was 1/2” down on that side and now measures hub to fender the same on both sides.
    The coil perch on the LCA isn’t directly in line with the knuckle so whatever spacer you add (barring any other unintended side effects like spring compressing more) will lift the vehicle more than the spacer height. I think you’re on the right track with the 3/4” spacer vs going for the full inch spacer
    1SilverRunner[OP] likes this.
  8. Jan 15, 2025 at 9:13 AM
    When I install Ironman FCP I noticed driver side had more preload from factory. I bet this is why I don't have lean.
    (Pic from one of my old posts)
  9. Jan 15, 2025 at 9:42 AM
    Agent_Outside
    Built 2011 T4R Limited
    I totally thought this was going to be about fuel trims
  10. Jan 15, 2025 at 11:19 AM
    1SilverRunner
    Tejas
    Thanks for the input guys. I contacted Mike at Exit off road and he recommended a 3/4" spacer to to replace my .4" spacer on the rear driver side.
    He also pointed out that if I lower the front passenger side (by reducing pre load) it will lift the rear driver side. I didn't even consider that.
    Big thanks to Mike at Exit Off Road.
