Knock/thunk sound over bumps
Discussion in '5th Gen 4Runners (2010-2024)' started by dmusic1996, Mar 19, 2021.
  1. Mar 19, 2021 at 10:12 AM
    dmusic1996
    dmusic1996 [OP] New Member
    2014 Toyota 4Runner Limited
    Hey guys, I have a 2014 Toyota 4runner Limited with a thunking sound over smaller bumps that seems to be coming from the drivers side front tire on the road. I had it in at a Les Schwab earlier today for an alignment/ tire rotation and asked if they would take it on a drive to see if they could hear the sound. Manager jumps into the truck and took it for a ride and confirmed with me he could hear the sound as well. They put it up on the lift and said i had a loose heat shield underneath the drivers seat which he tightened and said that was probably the culprit. I got in and started to make my way home, noise is still there. Any ideas what i should check next? The noise is super irritating.
    Update:
    This noise ONLY seems to happen in temperatures below 50 degrees Fahrenheit. It got up to about 70 degrees here in Denver Colorado the other day and the noise was completely gone. Temps dropped down to about 40 in the morning on my way to work and the noise was back.
  2. Mar 19, 2021 at 7:59 PM
    Joekader
    Joekader New Member
    Joe
    Check your sway bar links mine went bad at 9k got adjustable one no more thunks
    J
    Thatbassguy and Bodie the Dog like this.
  3. Mar 19, 2021 at 9:04 PM
    Bodie the Dog
    Bodie the Dog Danger Ranger!
    2016 TEP, 1994 SR5
    Shrockworks sliders & rear bumper, Toytec 3/2 lift, ARB diff mod, 8 pod RGB LED's, RCI steel front skids, Big Sky katana rack, Reese roof rack, cool stickers.
    I had a similar noise, it turned out to be the sway bar bushings.
  4. Mar 19, 2021 at 10:21 PM
    9MAJOR
    9MAJOR New Member
    2019 4Runner SR5 Premium
    On my 05 Tacoma there was a broken shock. Couldn’t tell until I had it pulled out to check
  5. Mar 19, 2021 at 11:04 PM
    Holy cow! That seems way premature for that.
