Knock sensor issue
Discussion in '4th Gen 4Runners (2003-2009)' started by LJM62, Aug 8, 2024.
  1. Aug 8, 2024 at 3:08 PM
    LJM62
    LJM62 [OP] New Member
    I have a 2006 SR5 2wd with the 4.7 V8. I have been getting a knock sensor code on the check engine from time to time. It doesn't always happen, but when it does its always after the vehicle has been sitting for at least 5 to 6 hours and comes on within about 5 minutes or so. I clear the code and its fine and doesn't come on again. This has been happening over the last year but not all the time. I have gone a couple of months without it re occurring. if anyone has any info thank you in advance.
  2. Aug 8, 2024 at 4:31 PM
    Ralph Blake
    Ralph Blake New Member
    2008 sr5 4runner
    Are you hearing a knock when pushing it hard? if not i can't see it as a major problem, people get many check engine warnings and then get the codes, Auto Zone gets rich selling people stuff they might or might not need.
  3. Aug 9, 2024 at 4:57 AM
    LJM62
    No, it runs great with over 193,000 miles on it. Be nice on Auto Zone, I have a part time job there lol.
  4. Aug 9, 2024 at 5:07 AM
    Ralph Blake
    2008 sr5 4runner
    I wish i had a dollar for everytime someone gets a check engine light and also a flashing antiskid warning, when all it is the gas cap needs tighting.
    You clean the caps o"ring keep it tight and clear the codes.
    Toyota designed it to send drivers to their dealer stealers service dept. to get a $500+ fix that is not needed.
  5. Aug 9, 2024 at 5:17 AM
    Oakboro, N.C
    Have you had a chance to check the harness to ensure no rodent has chewed through the wiring or has a nest set up?
  6. Aug 10, 2024 at 5:06 AM
    LJM62
    Had that happen about 7 yrs ago where I used to live, but have not seen any evidence of it. I did have the timing belt replaced about 18 months ago.
  7. Aug 10, 2024 at 6:00 AM
    Strongarm
    Strongarm New Member
    2023 4Runner
    If there are no signs of wire damage, I would replace it if it keeps popping a code. Its job is to advance or retard the timing depending on if any detonation/knock is detected. You may not hear or feel it happening.
  8. Aug 10, 2024 at 6:09 AM
    LJM62
    The issue is the intake manifold has to come off to replace the sensors, Since the problem is intermittent I want to be sure.
  9. Aug 11, 2024 at 5:15 AM
    Buckaroo
    Buckaroo New Member
    2005 Ltd T4R 4WD V6
    FSM knock sensor code troubleshooting attached. This should do the trick. Sensor may test good it problem is intermittent and you don't catch it at the right time. May want to test after sitting 5-6 hours since that seems to be when you are getting the code. Could also monitor test results while wiggling wire harness or tapping on intake manifold.
  10. Aug 11, 2024 at 6:00 AM
    Buckaroo
    Buckaroo New Member
    2005 Ltd T4R 4WD V6
    This diagram will help you find the EB1 connector. Doesn't appear you have to pull the intake manifold to get to it.
    The verbal description of the EB1 location is, "Engine No.2 Wire and Engine Wire (Near the Starter)".
  11. Aug 11, 2024 at 7:17 AM
    LJM62
    Great, thank you.
