Key fob trouble
Discussion in '5th Gen 4Runners (2010-2024)' started by Hardcopy1, May 3, 2023.
  1. May 3, 2023 at 11:32 AM
    Hardcopy1
    Hardcopy1 [OP] New Member
    2015 4 runner
    Need advice on reprogramming my key fobs. Both have new batteries but can’t open the back hatch or roll down the back window from outside the vehicle. Can only start the vehicle by placing the fob by the start button. 2015 Toyota 4 runner limited. Thanks.
  2. May 3, 2023 at 12:21 PM
    steelevo
    Utah
    Welcome. Are you sure that the batteries are the issue? Sounds like the new batteries are not working either. Maybe they are installed backward or a connector is broken?
    Captain Spalding likes this.
  3. May 3, 2023 at 12:29 PM
    Just for background info - the fobs were working before, and performed the functions mentioned? If so, why the battery change, unless it was determined to be 'time to do so'...
    Captain Spalding and steelevo like this.
  4. May 3, 2023 at 1:42 PM
    HuskyMike
    HuskyMike New Member
    Standard procedure if batteries are low/ dead in a fob is to have to put it close to the start button in order to start the vehicle. I'd check your batteries.
  5. May 3, 2023 at 1:48 PM
    Do the fobs unlock the doors?
    Did you change the batteries?
    Are the batteries installed the right way up?
    Are the batteries fresh?
    glwood54 and 08TXRunner like this.
  6. May 4, 2023 at 6:29 AM
    Hardcopy1
    2015 4 runner
    Thanks for all the advice. Turns out there is a setting on the navigation/radio screen under settings that was turned off. Thanks again!
  7. May 4, 2023 at 6:37 AM
    OverRunner
    OverRunner rebmeM weN
    Jared
    Denton, TX
    ‘21 ORP w/KDSS
    Thanks for sharing the resolution!!
    Yazzman likes this.
