Key Fob stopped locking and unlocking doors
Discussion in 'General 4Runner Talk' started by deh5056, Jun 27, 2024.
  1. Jun 27, 2024 at 3:09 AM
    deh5056
    deh5056 [OP] New Member
    2024 SR5
    None
    About two weeks after the purchase of a new 2024 4Runner SR5, the key fob quit unlocking and locking the doors using the buttons on the fob. Everything thing works when using the touch to the handles and the car starts and runs fine. Had the alarm people out twice. They tore the car apart and said it is not the alarm sold by Toyota at time of purchase. Anyone else had this problem? Thanks for any information!
  2. Jun 27, 2024 at 3:30 AM
    Welcome. Both fobs act that way? Before the alarm it was working?
  3. Jun 27, 2024 at 4:23 AM
    Strongarm
    Strongarm New Member
    2023 4Runner
    This usually happens when someone tries to turn down the volume of the beeps when locking or unlocking the doors. It seems to be a bug in the radio. The keyless transmitter signal gets turned off. The fix is either go to dealership and have them reset the keyless, or get a Carista app and do it yourself. If you go to the dealer have them adjust all of your customized settings. Like holding the unlock button to roll down all your windows at once.
    backpacker and java like this.
  4. Jun 27, 2024 at 4:24 AM
    deh5056
    2024 SR5
    None
    Yes doing it with both fobs. Worked fine for about three weeks after alarm was installed. I found a couple posts buried in a forum on this site after I posted. People have corrected the issue with a Carista. I ordered one. I was on the fence with getting one of those anyway. Apparently, it is a fairly common problem after you switch any of the settings for the locks and doors. I had just changed mine to open all four doors with the key fob opening. I noticed right after that.
  5. Jun 27, 2024 at 4:28 AM
    deh5056
    2024 SR5
    None
    I have the Carista coming tomorrow. Any advice on how to fix it with that? Thank You!
  6. Jun 27, 2024 at 4:47 AM
    Strongarm
    2023 4Runner
    Start your subscription, usually only one month is needed. Follow the prompts to customizable features. Adjust all settings. You will be surprised how adjustable most functions are.
  7. Jun 27, 2024 at 5:03 AM
    deh5056
    2024 SR5
    None
    And that will reset it?
  8. Jun 27, 2024 at 5:14 AM
    Strongarm
    2023 4Runner
    Normally yes. I accidentally turned my remote off the first day by turning down the volume of the door lock/unlock beeps. Found the fix on this forum.
    Mind you it should be a free adjustment by the selling dealer. I use Carista to adjust friends and family’s cars as well as my own.
  9. Jun 27, 2024 at 5:20 AM
    deh5056
    2024 SR5
    None
    OK Thank You very much. I am trying to avoid a trip to the dealer for a minor issue like this. Always such a pain in the ass at the dealer.
  10. Jun 27, 2024 at 5:26 AM
    Strongarm
    2023 4Runner
    It’s worth it for that reason alone. Good luck. Don’t be afraid to try all the different options like turning down the volume of your directionals, shutting off your seatbelt chime.
  11. Jun 27, 2024 at 5:42 AM
    java
    java fauxrunner
    2023 ORP ice cap
    Yeah happened to my '23, had to take it back to the dealer.
  12. Jun 27, 2024 at 7:55 AM
    Oakboro, N.C
    I wanted to check if this is the OEM keyless entry/alarm or an aftermarket alarm system, based off you stating that it worked for about three weeks after it was installed. If aftermarket, What brand did you go with?
  13. Jun 27, 2024 at 8:05 AM
    deh5056
    2024 SR5
    None
    It was one they sold me at the dealer at purchase. I think it was KARR.
  14. Jun 27, 2024 at 8:15 AM
    Oakboro, N.C
    Do you have a separate fob for the KARR system that is used opposed to the OEM fob?
    Also do you have the KARR app on your phone? I do recall reading about the KARR fob would activate and deactivate the alarm (only) but would only lock/unlock via Bluetooth on the KARR app. Just throwing out a few things I have heard over the years with these systems.
  15. Jun 27, 2024 at 8:22 AM
    deh5056
    2024 SR5
    None
    No separate fob. I had the KARR people out here twice. They tore it apart twice. No problem found with the alarm. Since looking around this forum and hearing from members, it appears this is not a rare thing. I will try the Carista thing when it gets here in a couple hours. That seems to be the easiest. If not, off to the dealer.
  16. Jun 27, 2024 at 8:30 AM
    Oakboro, N.C
    Copy that, Keep us updated as to the outcome with Carista!
  17. Jun 27, 2024 at 8:39 AM
    deh5056
    2024 SR5
    None
    I will. It is out for delivery with Amazon so shouldn't be too long.
  18. Jun 27, 2024 at 10:50 AM
    deh5056
    2024 SR5
    None
    For any of you that were wondering. The Carista arrived and after the usual set up, it took me 10 seconds to fix the issue. Remote lock was marked as disabled. Just clicked enable and it worked. Cost me 50 dollars, but worth it to me to avoid the dealer. To all that helped, Thank You!
    1SilverRunner likes this.
  19. Jun 27, 2024 at 11:48 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel kit (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-675v Springs) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Delete DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. Custom High Clearance Fender Liners *Coming soon Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: LFD Cross-Bars Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered, coming soon Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights OVS Nomadic 6.5' Awning AVS Low Profile Vent Visor AVS Bugflector II Diode Dynamic puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Now you can enable the "roll down windows with key fob"!
    My favorite option the carista unlocks
    steelevo and RumHamRunner73 like this.
  20. Jun 27, 2024 at 12:46 PM
    deh5056
    2024 SR5
    None
    Yes. Already did that!
