Keep or sell ???
Discussion in '5th Gen 4Runners (2010-2024)' started by jim c, Mar 2, 2025 at 8:20 AM.
  1. Mar 2, 2025 at 8:20 AM
    jim c
    jim c [OP] New Member
    Yesterday
    2011 black Toyota 4runner SR5
    I have a 2011 black 4runner SR5 with 125,000 miles on it. Am original owner. Everything is in great working order and all looks good interior and exterior. My dilemma is whether to keep it for a few more years or sell and buy new. Again, truck is in perfect working order, no repair issues, no dents, bangs or body work to fix....just 14 years old and have the itch for something new, but should I bite the bullet and just hang on to what works?
  2. Mar 2, 2025 at 8:22 AM
    Acesandeights
    Acesandeights #34
    2024 ORP
    Yes definitely.
    Oh, btw, where are you located? Might update your profile.
  3. Mar 2, 2025 at 8:31 AM
    Dude. If it ain't broken, don't replace it. Drive that thang' till the wheels fall off. A Toyota w/125k miles is barely broken in. That truck has (at minimum) 10yrs of life left.
    P.S. Post up pictures of this bad-ass rig!
    Imdav2u, Daddykool and catbrown357 like this.
  4. Mar 2, 2025 at 8:36 AM
    Oakboro, N.C
    In that condition, drive it...
  5. Mar 2, 2025 at 8:48 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    I have a 2011 Limited with 190K, in similar condition as what you describe. I have no intention of selling it. Ever. It's paid for, it's solid, it still looks good, and most importantly it keeps doing exactly what I ask of it. I think you know my answer.
    Henry J, JChiz and djwantke like this.
  6. Mar 2, 2025 at 8:51 AM
  7. Mar 2, 2025 at 8:57 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Welcome here Jim!
    It’s a good place to ask this question.
    2011 with no dents and dings!?
    Amazing.
    I could understand wanting to sell while you can still gets decent coin. Whatever you do just don’t buy a new 6th gen, yet.
  8. Mar 2, 2025 at 9:01 AM
    Texoma-Brad
    Texoma-Brad OK Yota
    Brad
    Texoma USA
    Ditto the above posts. 125k on the Gen 5 is nothing. I'd take a Gen 5 in perfect shape with a 100% known history over a new Gen 6 (or anything else with a 4Cyl turbo) any day.
  9. Mar 2, 2025 at 9:16 AM
    TheGreekFreak
    TheGreekFreak New Member
    Well, I never plan to sell mine, so my answer is keep.
    Even if the day comes where I need something more fuel efficient, smaller, etc. it will just have to be an addition, not a replacement.
    Texoma-Brad likes this.
  10. Mar 2, 2025 at 9:22 AM
    Grug556
    Grug556 New Member
    Kings, Crestone Rack, Baja S8, Baja Fogs, Baja XL80s, Baja mini cubes, SPOD, ARB compressor, RCI full skids, ROAM box and stuff. ST Pros. Shrockworks sliders... GOAT armour
    Keep... these low tech buses we drive we drive for a reason. Less tech is better. Drive it till it turns to dust or you do.
  11. Mar 2, 2025 at 9:40 AM
    S8ULATR
    S8ULATR New Member
    CA
    2 Germans & a Beast
    Keep it. But, to play on to your itch, maybe (if it makes sense for you) pick up a second used car for fun (and perhaps better mileage). Perhaps something fun with a manual transmission. There are ALOT of very nice used cars sub $10k that are reliable, easy to work on, and fun. Examples: E39 BMW 5 series (1997-2003), older Cayennes, many variants of Mercedes, Miatas. Just a thought, but it's a rabbit hole and before you know it you have 3 extra cars you don't need. Alot of said older fun cars can be insured through Hagerty for full coverage (not basic, legit like 250-500-250 limits) for under $300 / YEAR. It's a life hack, Hagerty is awesome.
    Your 4R sounds like a gem. All those years with such a wonderful car and I'd fear you'd miss it if you got rid of it.
  12. Mar 2, 2025 at 10:01 AM
    LCJ77
    LCJ77 New Member
    Gilbertsville,Pa.
    2023 TRD Pro Ice Cap
    Ever since my mid 20's I've always been in the 70-80k miles (1 exception 93 Mustang GT had 115k when traded) I trade even when there's nothing wrong with them no matter what make. this is my 5th Toyota, 08,12 FJ's 15 Tacoma A/C TRD Sport, 18 TRD Or. But that's just me. It's your $$ spend it how you feel or don't. Good luck with what ever you decide. I wouldn't buy a 6th for at least 3-5 years of proven data.
    NEguy likes this.
  13. Mar 2, 2025 at 10:46 AM
    welcome, have 149,500 on my 2011, in excellent shape and not going to sell it. Keep it.
  14. Mar 2, 2025 at 11:33 AM
    mac1usa
    mac1usa New Member
    Take the money you would spend on a new one and sock it away in a Roth IRA over time or whatever save it for your retirement!
    Keep that truck you have and enjoy it. As others said she’ll keep going. You’ll thank us years down the road and have more saved for retirement and you’ll enjoy that truck you got.
  15. Mar 2, 2025 at 5:10 PM
    Give Toyota a couple of years to work out the bugs in 6th gen, then re-evaluate in 2027.
    Saker and Nhmountainman like this.
  16. Mar 3, 2025 at 7:42 AM
    Keep it if you're just wanting something new. You did not say anything about that new thing being a 4runner. But your money, so if you are taking the good trade in prices for 5th gen then cool. But not worth it just for no need attached in my opinion. Wait until new prices come down a lot.
  17. Mar 3, 2025 at 7:48 AM
    Yamahamer
    Yamahamer New Member
    Nevada
    2022 4Runner Off Road
    So...you want to be a beta tester for the newest generation 4Runner with the turbo 4-banger? I'd wait a few years to let them get the bugs worked out!
