Keep or replace stock Bridgestone Dueler H/T tires?
Discussion in '5th Gen 4Runners (2010-2024)' started by Jedigolf, Jan 14, 2025 at 8:02 PM.
  1. Jan 14, 2025 at 8:02 PM
    Jedigolf
    Jedigolf [OP] Go4Runner
    2023 Gray Off Road Premium
    Are the stock Bridgestone Dueler H/T tires good enough for light snow and off roading? Certainly doesn't look good as some All Terrain tires but too new to just replace.
  2. Jan 14, 2025 at 8:28 PM
    They are pretty awful at anything but dry pavement.
  3. Jan 14, 2025 at 9:03 PM
    Texoma-Brad
    Texoma-Brad OK Yota
    Brad
    Texoma USA
    I yanked the Duelers off my Venture at 30k and went with 265 (OEM size) BFG KO2's. Never been happier with a tire than the KO2's. Run them on my Land Cruiser too. Duelers were quieter but looked out of place on the Venture. I also did the 1" Cornfed lift on the front only to level it out. Nothing extreme, but it looks like it's supposed to now.
    But, to answer your question - are the Duelers good enough for light snow and light trail drives. Yes, but barely... They're best rolling down the interstate.
  4. Jan 14, 2025 at 9:06 PM
    icebear Recovered Kia Owner
    Up to you and what you anticipate. For light dirt, gravel, small rocks, sand, they’ll do. If you have an opportunity to test them out without going out of your way, you could try.
    For snow, it’s a basic all-season so check expectations. I would drive gingerly on plowed/treated roads but probably would want to switch them out if conditions would be worse.
    Maybe you can sell them once replaced.
  5. Jan 14, 2025 at 9:33 PM
    Jedigolf
    Yeah...sounds like I'll have to change them out. I was looking at Toyo Open Country A/T III since that is lighter compared to Falken Wild Peaks (6 lbs heavier per tire vs 10 bls per tire). Do tire weights really make noticeable difference on how car drives?
  6. Jan 14, 2025 at 10:59 PM
    Photon_Chaser 48576 and counting…
    Roger
    Sierra Nevada Mountains
    I ran the Duellers on my rig for a full year, if I had to choose aside from an AT I would stick with Michelins as I did on my 3rd Gen. They'll be okay on simple (flat) trails and dusty forest service roads and the like otherwise I would not go too far off pavement with them.
    1/2" of mud and you're spinning rubber, fair on-pavement in rain, snow is a crap shoot (go SLOW!)
    Increased unsprung weight affects MPG and in conjunction with suspension can make for a rougher ride.
    Sidewall stiffness can greatly affect handling in turns and becomes more pronounced as aspect ratio increases.
    Jedigolf[OP] and icebear like this.
