KDSS questions
Discussion in '5th Gen 4Runners (2010-2024)' started by AChar, Mar 26, 2023.
  1. Mar 26, 2023 at 1:20 PM
    AChar
    AChar [OP] New Member
    AC
    Gen5
    nothing yet
    4R ORP should be here in a month or so... Opted to go with KDSS for a couple reasons A) its what was coming available and B) I will be using this as a daily driver 90+% of the time. However, I do have a few questions for those that have and understand KDSS:
    1) some folks say the KDSS softens below 12 MPH, and other say it only softens if you are in 4 Low and below 12mph. Can anyone confirm if its only in 4 Low or if it any time 2W, 4W.. etc. below 12 MPH?
    2) There will be times where I might spend the day or weekend on rougher logging trails and will probably average 30+ MPH. Has anyone installed Dr. KDSS switch to allow softening the ride above 12 MPH? If so, what has your experience been... is it worth it? When softened, is it like a 4Runner without KDSS, or is it even softer?
    any feedback/suggestions are greatly appreciated.. I can't wait to get my rig! :)
    djwantke likes this.
  2. Mar 26, 2023 at 1:27 PM
    As far as I can tell, the valves open below 12 miles per hour no matter what drive mode you are in.
    I don't personally have the doctor KDSS controller, but I hear good things about it.
  3. Mar 26, 2023 at 1:30 PM
    airup12
    airup12 New Member
    I don’t know exactly when it softens. Definitely at the lower mph. I will say having owned a few 5th gens as a daily driver the one with kdss is the smoothest on road. You don’t feel it roll as much with corners and turns. When you try to turn 90 degrees the thing cuts it like butter. This is true in both 4hi and 4 lo.
    My daughter in my wife’s rav says she feels like she falling when my wife takes corners hard. In the 4runner with kdss she doesn’t even notice.
    Hope that helps a little
  4. Mar 26, 2023 at 1:30 PM
    Cleazy
    Cleazy New Member
    San Diego CA
    2021 TRD ORP MGM
    KO2 285/70/17 FN FX Pro Wheels Dobinsons Suspension 2.5/1.5 OME UCAs Sherpa Roof Rack Alpharex Luxx Tails
    I have Dr. KDSS and it makes a big difference on dirt and washboard roads. Install is super easy and regret not getting it sooner.
    Thatbassguy and djwantke like this.
  5. Mar 26, 2023 at 1:44 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    @AChar great questions, I'm wondering the same things. I'll reach out to you very soon, I just opened the kit
  6. Mar 26, 2023 at 5:07 PM
    AChar
    AC
    Gen5
    nothing yet
    Awesome.. love to know how it works, how hard it was to put in, and where you put the switch :)
  7. Mar 26, 2023 at 7:28 PM
    The gentleman I met with on Friday to do the tune on my 4R has the Dr. KDSS switch, and he loves it. He also said on long highway drives with no major curves or turns it rides much better with the KDSS turned off. FWIW
  8. Mar 26, 2023 at 7:42 PM
    Installation is easy. The supplied instructions are very detailed. I put my switch in the second spot from the left by my left knee.
  9. Mar 27, 2023 at 6:49 AM
    5six
    5six New Member
    55_4Runner
    GTA, Ontario, Canada
    2022 Black TRD ORP
    My DR KDSS order is on the way (KDSS switch, harness, front sway bar stuff for lift). Really curious about non hwy driving, especially since my ride is a firmer than stock after lift.
  10. Mar 27, 2023 at 8:58 AM
    Interesting. I don’t know if the DrKDSS switch will help in your case as much as it would with a softer stock suspension.
    5six[QUOTED] likes this.
