KDSS Lift Question
Discussion in 'Suspension' started by adventure_t4r, May 5, 2021.
  1. May 5, 2021 at 3:07 PM
    adventure_t4r
    adventure_t4r [OP] New Member
    Cody
    1999 SR5 & 2017 TRD Off-Road Premium
    When looking for rear lift springs, what is the difference between regular coils and coils designed for KDSS?
    DrewMan likes this.
  2. May 5, 2021 at 3:33 PM
    Mtbpsych
    Mtbpsych New Member
    Generally from what I’ve read with KDSS it’s recommended you don’t go above 2” of lift, so most KDSS specific coils don’t go higher. You can though, but you’ll need a drop bracket for the rear sway bar. Someone else with KDSS can chime in but that’s what i think it is.
  3. May 5, 2021 at 3:42 PM
    I'm at 3" no problem.
    I'm not sure what drop bracket was required I didn't order one and had no issues. Unless my guy installed it for free.
    Track bar is optional but I got one anyways.
    There are some coils that adjust for the lean. But I got icon coilovers and adjusted for the lean by adjusting the coilover.
  4. May 5, 2021 at 3:45 PM
    Mtbpsych
    Mtbpsych New Member
    Bracket isn’t required, but helps realign everything to avoid Amy potential failure while doing articulate trails. If you aren’t doing serious articulation you probably won’t need it.
  5. May 5, 2021 at 3:46 PM
    Think you mean track bar then. That aligns the rear end.
  6. May 5, 2021 at 3:50 PM
    Mtbpsych
    Mtbpsych New Member
    DrewMan likes this.
  7. May 5, 2021 at 3:56 PM
    Found this from one of our previous posts.
  8. May 5, 2021 at 3:56 PM
    adventure_t4r
    Cody
    Mtbpsych[QUOTED] likes this.
  9. May 5, 2021 at 4:14 PM
    Well my offroading will never be extreme enough so guess depend on the owner.
    DrewMan and Mtbpsych like this.
  10. May 5, 2021 at 5:36 PM
    Rock-N-Roll
    Rock-N-Roll TRD Amateur
    2021 T4R ORP w/ KDSS
    I just bought a 2021 with KDSS and will be installing a 3" up front and a 2" in the rear at the end of July. I will circle back here to try and confirm if, at full droop, there is any contact with a 2" lift on the back once the lift is installed.
    DrewMan likes this.
  11. May 5, 2021 at 6:04 PM
    Mtbpsych
    Mtbpsych New Member
    2” is fine, anything more you risk having contact according to that article linked above.
    Rock-N-Roll[QUOTED] likes this.
  12. May 5, 2021 at 6:11 PM
    I'm not sure how the lift height would cause this, unless it comes with extended travel. Otherwise, if travel isn't extended, it shouldn't be an issue. :notsure:
    Rock-N-Roll likes this.
  13. May 5, 2021 at 6:28 PM
    Mtbpsych
    Mtbpsych New Member
    I don’t have KDSS so I can’t vouch for anything. The guy who runs that page is pretty well versed in the 4runner world so I would trust he has an idea of what he’s saying:notsure:
    I think it’s @trail4r
  14. May 5, 2021 at 6:35 PM
    Rock-N-Roll
    Either way I'll confirm with pictures here for future reference. :cheers:
  15. May 5, 2021 at 6:37 PM
    Just to clarify I'm at 2" in rear and 3" front.
    Not 3" in the rear.
    Thatbassguy and Rock-N-Roll like this.
  16. May 6, 2021 at 6:32 AM
    grizzlypath
    grizzlypath New Member
    2020 ORP-KDSS
    I'm also at 3" without any issues. I believe the difference in "KDSS springs" is that one is slightly longer to help counter the potential sag that some get. I don't think my rear springs are KDSS specific, but I didn't personally notice any sag so I'm not worried about it.
    DrewMan and Rock-N-Roll like this.
  17. May 6, 2021 at 11:22 AM
    I believe the non-KDSS springs are actually different lengths. I am guessing that you are referring to the driver side lean.
  18. May 6, 2021 at 3:46 PM
    adventure_t4r
    Cody
    I think this is the first answer to my original question haha
  19. May 6, 2021 at 4:11 PM
    LA260
    LA260 New Member
    KDSS rear springs are different heights. I have Dobinsons KDSS specific rear springs and there is a height difference between the two. The passenger side was higher/longer than the drivers side and they were also labeled.
    You can use a 10/15.. spacer to do the same if the springs are not KDSS specific assuming there is a lean
    grizzlypath and DrewMan like this.
  20. May 6, 2021 at 4:34 PM
    It seems unusual that the springs for KDSS equipped vehicles would be different lengths since they should be less likely to lean than non KDSS 4Runners.
    I have Bilstein 6112's which recommend using a higher setting for the driver's side for non-KDSS 4Runners and the same setting on both sides for KDSS equipped 4runners. Mine are both set to the same height and I have no lean.
  21. May 7, 2021 at 10:09 AM
    Living the dream
    Living the dream New Member
    ABQ
    2019 T4R Off-Road KDSS
  22. May 13, 2021 at 7:48 AM
    AccuTune Offroad
    AccuTune Offroad New Member Vendor
    2.5" Fox Suspension
    This video may help explain and show some of the issues you can encounter lifting a KDSS equipped 4Runner too tall. The Black Gate Customs drop brackets can be a great addition to help with clearance if you are after a tall lift or want to run long shocks. Another limiting factor is the upper control arm hitting the gas tank at full droop if you have too long of a shock, but most wont run into that issue.
    https://youtu.be/ROJ3V1yfqLQ
    kmeeg likes this.
  23. May 13, 2021 at 8:13 AM
    Thank you AccuTune for providing valuable info. When ever I say when lifting KDSS vehicle to work with a company like you who knows about KDSS people often seem to comment "its no different than non KDSS". Appreciate all that info AccuTune..:cheers:
  24. May 13, 2021 at 8:44 AM
    captrussia253
    captrussia253 New Member
    Ruslan
    I added a toytec 1/2" spacer up front and Ironman 3/4" spacer in the rear of the passenger side to adjust for the lean. Friend of mine with the same lift didnt have lean issues. KDSS is a hit/miss and some get lucky with no lean.
