KDDS Spacers
Discussion in 'Suspension' started by BigB_Money, Feb 5, 2023.
  1. Feb 5, 2023 at 2:01 PM
    BigB_Money
    BigB_Money [OP] New Member
    Brian
    2020 White TRD OffRoad 4Runner
    Led Headlights, Low & Hi Pedal Commander Cooper Discoverer AT3 LT Bilstein 5100’s all around Front @ 1.75”, Rear 1”ish (30mm) Whiteline spacer
    I have a 2020 ORP, 5100’s @ 1-3/4” stock springs up front. 5100’s with 30mm spacers in rear. Rolling on stock wheels with 275/70’s. Ever since I put the the 5100’s and tires I hear a clunking in the front end. I’ve checked everything and the only item I can contribute it to is the KDDS sway bar. Has anyone else experienced this at this height and do the KDDS spacer kits resolve the issue? Thanks for any input…
  2. Feb 9, 2023 at 11:20 AM
    David@Toytec
    David@Toytec New Member Vendor
    David
    Denver Colorado
    2005 4Runner
    To much
    Most likely not the KDSS system clunking, especially at the 2020 year model. Quite possibly a improper build on the coilovers when they were swapped out, there is a series of bushing/ washers that are required to be build in specific order when coilovers are assembled. Can you provide some photos of the coilovers, top mount location? The KDSS spacer will not do anything positive for you for this matter.
  3. Feb 9, 2023 at 11:34 AM
    Dabigono
    Dabigono Just Joined
    2020 4Runner
    I would make sure everything is torqued down to spec, make sure nothing was left loose…
  4. Feb 9, 2023 at 12:18 PM
    Is 2020 too new to check KDSS bushings?
  5. Feb 22, 2023 at 10:21 AM
    CalcityRenegade
    CalcityRenegade New Member
    Matt
    2023 T4R ORP KDSS
    My money would be on the front shock bushing/spacers not being built in the correct orientation. This is a common issue with 5100's on 1st gen Nissan Titan's.
