Is this Toyota wheel same specs as 4 Runner factory ORP?
Discussion in '5th Gen 4Runners (2010-2024)' started by rmiked, Mar 20, 2023.
  1. Mar 20, 2023 at 5:06 AM
    rmiked
    rmiked [OP] New Member
    Fort Mill, SC
    I am wondering if I installed this wheel on a new ORP , if stock sized tires 265/70/17, would not rub? My main question is are the specs: 17 x 7” wheel, 4 mm offset and 4.16” backspacing the same as factory?
  2. Mar 20, 2023 at 6:06 AM
    MTBVRF
    MTBVRF New Member
    South Central PA
    2021 NB Limited
  3. Mar 20, 2023 at 6:09 AM
    rmiked
    Fort Mill, SC
    Will that 1/2” outward move cause the tire to rub the fenders? I assume this means more clearance away from the upper control arms. If this is the same wheel as installed with the XP package, it must not cause rubbing? I see from the link you posted, the factory ORP wheel is 7.5” wide vs the 7.0” black TRD wheel. The extra 1/2” width would pinch the tire somewhat less. I like the 7 spoke factory wheel but I saw an XP package ORP and the black wheels with red center cap lettering looked good, especially when the wheels are clean
  4. Mar 20, 2023 at 6:55 AM
    CJT4Runner
    CJT4Runner Frosty
    Chris
    ‘20 TRD ORP
    It will not rub. I have these wheel on 265/70/17 Toyos and a 2020 Off Road, no rubbin.
  5. Mar 20, 2023 at 7:03 AM
    rmiked
    Fort Mill, SC
    Thanks!
  6. Mar 20, 2023 at 7:03 AM
    This is the same wheel that comes stock on the PRO trim.
    They will fit, but they could rub depending on the tire you choose and your alignment specs. Even some 265's will rub.
    Toyota modifies the PRO by pushing the fender liner forward and doing a small trim on the fender flare to accommodate the lower offset of these PRO wheels.
    Captain Spalding likes this.
  7. Mar 20, 2023 at 7:35 AM
    Running those rims with 265’s and formally 285’s. No rubbing.
