Ironman4X4 Pro Cell Lift
Discussion in '5th Gen 4Runners (2010-2024)' started by VA_TRDORP2018, Mar 3, 2021.
  1. Mar 3, 2021 at 11:46 AM
    VA_TRDORP2018
    VA_TRDORP2018 [OP] New Member
    Dan
    2018 T4R TRDORP
    sliders, roof rack, molle panels, ditch lights, 3" lift
    Looking for advice/recommendations.
    I have a 2018 TRD ORP W/KDSS and installed the Ironman4x4 Foam Cell Pro stage 2 with performance load springs and prebuilt coilovers.
    The measurements from center hub to fender are as follows:
    Both front are 21.75”
    Both rear are 24”
    After corresponding with Ironman USA:
    "Measure all four corners of your vehicle from the center of the wheel hub straight up to the fender. Decide how much you want to raise the front and divide by 2"
    To get the front “level” I would need to adjust the preload of the coil overs by 1.125...?IMG_7934.HEIC.jpg
    Ultimately looking to put 255/80/17's on it.
    TIA
  2. Mar 3, 2021 at 12:04 PM
    koukimonster
    koukimonster DYNO4
    Appalachia
    Midnight Venture
    Yes raise the front threads by an inch and you should be level.
  3. Mar 3, 2021 at 9:13 PM
    Tuco S.
    Tuco S. New Member
    When you say "level" do you mean you want zero rake from front to back? If you do that and add any weight in the back it will cause the back to sag a bit and have a negative rake.
  4. Mar 3, 2021 at 9:21 PM
    GrantA
    North Carolina
    Fully locked 2020 SR5 Premium
    I am interested in seeing what it looks like when you are done making the adjustments. I have my ironman foam cell pro stage 3 coming next month.
  5. Mar 4, 2021 at 5:14 AM
    VA_TRDORP2018
    Dan
    2018 T4R TRDORP
    I just want less rake.
  6. Mar 4, 2021 at 11:11 AM
    VA_TRDORP2018
    Dan
    2018 T4R TRDORP
    Ill post some pics once I'm done, right now the plan is to do it on Saturday. Probably gonna add 1/2" preload to get another 1" in the front.
    GrantA[QUOTED] and fajitas21 like this.
  7. Mar 4, 2021 at 11:43 AM
    fajitas21
    fajitas21 New Member
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    Good compromise. If you're 1/2 - 3/4 down in the front the truck will still look level, but you'll not go negative too quickly when you load up the back.
    Tuco S. likes this.
  8. Mar 8, 2021 at 5:09 AM
    VA_TRDORP2018
    Dan
    2018 T4R TRDORP
    Unfortunately I was not able to get it done this weekend... The spanner wrenches I ordered didn't work with the Ironman 4x4 coil overs.
  9. Apr 4, 2021 at 4:49 AM
    Hrjaw
    Hrjaw New Member
    Roger
    2019 TRD ORP
    Ironman lift, JBA UCA
    Wondering if you ever adjusted? I have the same set up and was told I needed to remove the struts to adjust and have no desire to do so for a small adjustment. I was hoping it can be adjusted on the vehicle.
  10. Apr 4, 2021 at 7:01 AM
    VA_TRDORP2018
    Dan
    2018 T4R TRDORP
    Was waiting for Ironman to get their wrench back in stock (which I just checked and it is)
    Didn’t want to spend $79 on a coil over tool but I guess I’m kinda stuck.
    My plan was to adjust in place though...
  11. Apr 4, 2021 at 8:40 AM
    Hrjaw
    Hrjaw New Member
    Roger
    2019 TRD ORP
    funny I just received my wrench last week as well. Took a while.
