Ironman UCA question
Discussion in '5th Gen 4Runners (2010-2024)' started by TrueTexas, Sep 7, 2022.
  1. Sep 7, 2022 at 10:48 AM
    TrueTexas
    TrueTexas [OP] New Member
    The Woodlands, TX
    Hey Everyone. For those of you running Ironman UCAs, what caster setting was built in? Ironmans website claims 4 degrees but the video from Tinkerers garage claims that it has 2 degrees.
    https://www.youtube.com/watch?v=huMztKaHsUE&t=483s
    time stamp 7:20
    I have been chatting with Ironman and unfortunately, it is an engineering question that the marketing team cannot really answer. They are asking engineering but in the meantime I thought I would check here.
    My caster alignment is currently maxed at 2.0/2.4 and I'd like to dial it in to 3.5. If it truly is closer to 2 degrees, it is the right arm for me.
    Anyone have any real world experience that would help determine if it is 2 degrees or 4?
    Any other feedback on Ironman UCA's?
  2. Sep 7, 2022 at 12:45 PM
    TrueTexas
    The Woodlands, TX
    Looks like the pinned comment on the video above is from Ironman saying it is 2 degrees of correction.
  3. Sep 7, 2022 at 1:41 PM
    DSRunner
    DSRunner New Member
    I ran Ironman UCAs on my 2016 4R and got 3.5 degrees. I just bought another set of Ironman UCA for my 2022 4R.
  4. Sep 7, 2022 at 2:04 PM
    Looks like my caster on stock setup is 3.16.
  5. Sep 7, 2022 at 3:38 PM
    TrueTexas
    The Woodlands, TX
    Thanks @DSRunner . I like that they have rubber bushings and easy to source parts if I ever need them.
    @Slopemaster - Is that 100% stock?
    I dont have measurements stock but with only a mild lift (1.75"F/1"R), my caster was at 1.6/1.4.
    I am currently maxed out with 2.0/2.4 caster with .1/.3 camber. I would really like to get to 3.5 caster with the same camber as I currently have.
    I think the only way to do it is to add the UCAs. The 2 degrees the Ironman UCAs add should let me dial it in perfectly
  6. Sep 7, 2022 at 4:17 PM
    Crank_Mancastle
    Crank_Mancastle Professional Wanker
    Austin
    2016 Trail Premium
    Eibach Pro Truck kit Ironman Pro-forge UCS's Rocktrix RT110'S in bronze, 17x9 Toyo AT3'S 285/70/17
    I got 3.4 caster on mine.
  7. Sep 7, 2022 at 4:23 PM
    TrueTexas
    The Woodlands, TX
    @Crank_Mancastle. Thanks.
    I'm originally from Austin. Just moved out here about 8 years ago. Used to wheel on the service roads to the radio towers off loop 360 back in the early 90s when there was nothing else there.
  8. Sep 7, 2022 at 6:20 PM
    Ripmo
    Ripmo New Member
    2022 Lunar Rock ORP
    Bilstein 5100 2” front Bilstein 5100 rear w/ 1” Cornfed spacer Sherpa Crestone roof rack RCI Skids and sliders Ironman UCA’s
    Was wondering this same thing as these look like a great aftermarket option and with my 1.75” lift I’m getting about 2.7° of caster. 2° additional seems like it would be about perfect.
  9. Sep 7, 2022 at 11:01 PM
    Yes my 4R suspension is 100% stock.
