Internals of my engine from oil pan removal
Discussion in '3rd Gen 4Runners (1996-2002)' started by CoolToyota, Apr 24, 2024.
  1. Apr 24, 2024 at 8:29 PM
    CoolToyota
    CoolToyota [OP] New Member
    98 4Runner 1A5
    Well doing the oil pump and oil and wondered at 320k+miles wonder how this compares to as expected, normal.
  2. Apr 24, 2024 at 11:46 PM
    That's not too bad. Looks like oil wasn't changed as often as it should be though. When I pulled the valve covers on my 285k engine, it was beautiful inside.
  3. Apr 25, 2024 at 2:38 AM
    CoolToyota
    98 4Runner 1A5
    That’s what I was thinking - is there anything I could add w oil liquid liquid Molly or would that cause other issues ? This is the first time changing the oil since I’ve had her.
  4. Apr 25, 2024 at 6:07 AM
    I would just change it often from here on out. A few oil changes with good quality filters and oil will clean it out.
    kolter45 and 1SilverRunner like this.
  5. Apr 25, 2024 at 2:03 PM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-675v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Delete DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: LFD Cross-Bars Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered. Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights OVS Nomadic 6.5' Awning AVS Low Profile Vent Visor AVS Bugflector II Diode Dynamic puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Looks great. An oil with lots of detergents will help keep the engine clean but is not necessary. Pennzoil Ultra Platinum comes to mind.
    Overall though I don't see any sludge so just keep the oil changed and she's golden. Pun not intended.
  6. Apr 25, 2024 at 6:11 PM
    Pennzoil will clean that. Amsoil will work better but is expensive
  7. Apr 25, 2024 at 6:38 PM
    CoolToyota
    98 4Runner 1A5
    All sounds good ! Thanks for the input all
  8. Apr 25, 2024 at 6:53 PM
    Ahh 320K looks fine.
    Still good to go.
    MyWyfsRnnr likes this.
  9. Apr 26, 2024 at 7:26 PM
    CoolToyota
    98 4Runner 1A5
    Now a stupid question - when using the Toyota Seal Packing 103 (FIPG) there was a video that said not to apply in the groove of the water pump however I’m doing the oil pump and it seem per the manual you apply into the groove - am I overthinking things ? And what is the metal tool with the material ? Clearly I’m a newbie at this !!
  10. Apr 27, 2024 at 8:25 AM
    Brodie
    Brodie New Member
    Richmond, Va
    2021 Grey 4Runner SR5
    Tube Roller Key. Used to get everything out of the tube, such as toothpaste tube.
    BentRunner likes this.
