Intermittent Motor Acceleration Sound at Low A/C Fan Speeds
Discussion in '5th Gen 4Runners (2010-2024)' started by PerryChuan, Jul 26, 2024.
  1. Jul 26, 2024 at 9:54 AM
    PerryChuan
    PerryChuan [OP] New Member
    Hello everyone. Have a 2024 4Runner TRD Off-road with 1300 miles. While driving, every 20 seconds or so, I can hear a motor acceleration sound for about 2 seconds, but there's no noticeable increase in airflow from the vent, and the sound cannot be recorded. This only happens while driving and when the AC is on and fan speed is set to low, 2th, 3th. The sound is not present at low speeds (<10 mph) or when the car is completely stopped. I tried replacing the blower with an aftermarket one, but the sound persists. Both the cabin air filter and the blowers are very clean. Is this sound normal? Does anyone else have this experience? Thanks!
  2. Jul 26, 2024 at 10:01 AM
    I bet the AC compressor is kicking on and the load is drawing enough power to slow down the blower then letting it speed up when the compressor disengages until power stabilizes. It's a 24 though so have the dealer inspect it.
    Lc200 likes this.
  3. Jul 26, 2024 at 10:38 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    I'll never understand why someone with a brand new vehicle wouldn't take these issues directly to the dealer. And why would you install an aftermarket blower? I would be surprised if the dealer will honor any warranty work due to that alone. SMH...And, I agree with @whippersnapper02 that it has to do with load on the compressor, which is not normal.
  4. Jul 26, 2024 at 1:13 PM
    Oakboro, N.C
    Do you have ventilated seats and rock back on forth while driving?
  5. Jul 26, 2024 at 1:14 PM
    PerryChuan
    Thank you very much for the insight!
  6. Jul 26, 2024 at 1:15 PM
    PerryChuan
    Had a bad experience with the dealer before, so I am trying to avoid them if possible. I used the aftermarket blower to see if blower was the issue, but I’ve switched back to the OEM one now. Thanks for the advice!
  7. Jul 26, 2024 at 1:20 PM
    PerryChuan
    I don't have ventilated seats, but my seats don't make noise so far.
  8. Jul 26, 2024 at 1:35 PM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    It is just your AC compressor doing its AC compressing thing. Speeding up and down depending upon the load and temperature.
