Increased stopping power?
Discussion in '3rd Gen 4Runners (1996-2002)' started by senior master, Feb 1, 2021.
  1. Feb 1, 2021 at 12:34 PM
    senior master
    senior master [OP] New Member
    2002 toyota 4 runner limited 4x4
    stock
    I have a 2002 toyota 4runner limited 4x4 I need to up grade the brakes is there any aftermarket of good quality available or should I change the brakes over to a tundra brake system need to know what is the best way to go I WOULD LIKE MORE STOPPING POWER
  2. Feb 1, 2021 at 3:57 PM
    Welcome from Wisconsin!
    7385 likes this.
  3. Feb 1, 2021 at 8:26 PM
    treyus30
    treyus30 New Member
    Trey
    '99 Limited & '99 Tacoma PreRunner
    Tundra + stainless steel lines
    senior master[OP] likes this.
  4. Feb 1, 2021 at 11:57 PM
    ian408
    ian408 New Member
    Ian
    5th Gen TRD Offroad Pro - Super White
    Pls Stdby
    Stop Tech makes a bigger brake kit. Stainless lines will help but I don’t think it will matter that much. Maybe a bigger master cylinder.
  5. Feb 2, 2021 at 1:00 PM
    senior master
    stock
  6. Jan 22, 2022 at 7:20 PM
    ian408
    ian408 New Member
    Ian
    Pls Stdby
    I know this thread is a bit older but maybe it's of some help to another. The bigger brake kit does help. Installed on my Tacoma. But realistically, if you go the bigger brake route, the bigger master cylinder will help. You'll also want to be sure the bigger calipers will clear whatever wheels you have installed.
